Damn, I was writing for like 15 minutes to you man, and accidentally clicked back button on a keyboard with backspace while not in text field... sh&t accumulates fast when you are frustrated like that for sure. which is why I also hate forums, so inefficient.
Anyways, not gonna rewrite all that again... the most important was to thank you for your help.
I am using a pre-made rpi4 image from linuxcnc website, therefore all those paths were an unknown to me - I haven't installed linuxcnc at all, it came preinstalled there.
for wifi I do need it at least for testing, as it is impossible to stand for days in my garage (where it is going now apparently). But I got that working actually. was misguided again into installing a gnome network-manager, which caused more problem that I had before that and messed up configuration files for me. once I figure all the correct settings and everything, I will reflush the OS and do a cleaner setup for sure. Also it is really handy for file transfer as I use XRDP + remote desktop on windows, I can make a CAM this way and just drag and drop it without having to worry about using flash drives etc.
So my steps so far:
1) installed an ISO from linuxcnc on RPI4
2) ran PNC conf, tuned everything there (pretty straightforward and nice there and all was on schedule so to speak and I was pretty happy with the progress)
3) realized that I cant manually change a tool in gmoccapy, spent another hour walking around with "wtf face".
4) started messing with adding that functionality, which already turned into 5x more time wasted than the whole previous setup where machine was already working fine, just with one tool.
5) went to GMOCCAPY documentation (
linuxcnc.org/docs/2.8/html/gui/gmoccapy....l-measurement-videos
), found kind of tutorial, followed it carefully 3 times already. That turned linuxcnc into a frozen mammoth and nothing works at all now. HAL pins are connected correctly and I can see them changing TRUE/FALSE when triggered inside linuxcnc. the guy in docs also used PROBE variable instead of standard PROBE-IN, which by itself may have messed things up, but I am not sure how to troubleshoot that.
All my config files are attached, or so I think.
If anyone feels generous with their time, here are my messengers:
t.me/vladcronos
m.me/vladcronos
. Would be actually much faster over there. Thanks in advance!
