Nope, it is possibly less than two lines, all you need to do is stop disabling joging controls and let user overwrite Z0
I do not know why one would need to pause like that.
If the tool breaks or swarf wraps 1 inch into a 10 inch long cut, you need to stop now.
My only concern was a tool change purpose. In which case it will not be a sudden pause, it will be a preprogrammed tool change command. As I see it, if you can easily do that just by simply splitting your gcode file into separate files
or for example execute a RUN FROM HERE command assigning a line number.
All of aforementioned, as I see it, is not related to the situation described in that article.
With that said, once I programmed a tool change gcode, it is just so much better than doing that manually anyways, so I dont think anyone should even bother with a fully manual tool Z reset. The setup doesnt even need any investment if you do it like I did for example. So its a no brainer simpler and shorter solution anyway.
