Question about rotary toolpath display.
- color
- Visitor
15 May 2015 02:44 #58704
by color
Question about rotary toolpath display. was created by color
Hi to all,
I have a 4 axis CNC milling machine and I can not configure Linuxcnc to display rotary toolpath. When joging A axis the visualisation of the tool is corrrect but if I load a G code with some rotary toolpath, it isn't displayed correct, I only see a flat blue lines and the tool moves in flat surface instead rotary traectory. If I load a 3axys G code I see the entire model with white lines and the tool follow exact path but in rotary don't. Is this bug in AXIS or my configuration is wrong?
- ArcEye
- Thank you received: 240
15 May 2015 16:50 #58715
by ArcEye
Replied by ArcEye on topic Question about rotary toolpath display.
- color
- Visitor
15 May 2015 17:14 #58717
by color
Replied by color on topic Question about rotary toolpath display.
Thank you for the answer, ArcEye
I have set my INI file to GEOMETRY = XYZA. I see the tool cone rotate around X axis when jog it, but don't see the toolpath like a 3D object. Do you mean that this is impossible in Linuxcnc and the rotary toolpath is displayed always wrapped?
- ArcEye
15 May 2015 17:17 #58718
by ArcEye
There is a limit to what you can get a 2D display to show
Did you try this one?
www.linuxcnc.org/index.php/english/forum...s-on-cylinders#40497
- color
- Visitor
15 May 2015 17:29 #58720
by color
Not yet, I will try this. I must change INI to 9axix GEOMETRY if I understand correct?
15 May 2015 17:31 #58721
No, you just need to use GEOMETRY=AXYZ rather than XYZA
Replied by andypugh on topic Question about rotary toolpath display.
- color
- Visitor
15 May 2015 18:33 - 16 May 2015 12:02 #58728
by color
Ah, OK, Thanks.
I will try this .
Update - the AXYZ configuration works, but now have the following bug: When open G code and the machine is set in zero machine coordinate, everything looks fine. When do touchoff and set G54 or G55 or other user specified position, the visualisation of the toolpath start deforming. Like a sample, the ring with 30mm diameter looks like a ring with 120mm diameter. I tried AXYZ, XAYZ and XYAZ, always the same result.
I will try this .
Last edit: 16 May 2015 12:02 by color.
- neller
25 Nov 2019 11:32 #151210
by neller
Replied by neller on topic Question about rotary toolpath display.
Any solutions this?
Hello all, I have the same issue "the visualisation of the toolpath start deforming".It happens when we works in non-zero absolute coordinates, but I think the physical aspect works fine: this issue appears only on visualisation window.
28 Nov 2019 19:50 #151450
Sorry, no, that is just the way it is. The graphical preview has no way to know where the centre of rotation is relative to your work coordinate system. (Literally no way, this is not an easy thing to fix)
The following user(s) said Thank You: joekline9
- Matt Hat
18 Jan 2022 23:13 - 18 Jan 2022 23:14 #232357
by Matt Hat
Replied by Matt Hat on topic Question about rotary toolpath display.
Anyway to define the rotation axis of the displayed tool cone? A least it should be possible to define it in G54 abs coordinates? in my setup the axis for A is parallel to x (ok) but shifted to z=limit_z > 0 which is weird. I would expect rotation about local (y,z)=0, respecting G92 offsets.
Last edit: 18 Jan 2022 23:14 by Matt Hat.
Time to create page: 0.828 seconds
