Question about rotary toolpath display.
18 Jan 2022 23:40 #232363 by dgarrett
Replied by dgarrett on topic Question about rotary toolpath display.
master branch:
> 9. Rotations are by default applied with respect to the machine
> origin. Example: GEOMETRY=CXYZ first translates the control
> point to X,Y,Z and then performs a C rotation about the Z
> axis centered at the machine origin.
> 10. Rotations applied after translations may use the "!"
> provision to to act with respect to the current machine
> offset. Example: GEOMETRY=!CXYZ translates the control point
> to the X,Y,Z position and then performs a C rotation about
> the machine origin displaced by the current G5x,G92 X,Y,Z
offsets. (Changing offsets may require a program reload).
Ref:
linuxcnc.org/docs/devel/html/config/ini-...tml#_display_section
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
19 Jan 2022 13:47 #232434 by andypugh
Replied by andypugh on topic Question about rotary toolpath display.
I wonder how much work it would be to also allow a "magic comment" in the G-code to define the rotation axis?
(ROTATION, 10 20 30)
Or something.
The issue is propagating that info into the preview, I would imagine.
Time to create page: 0.109 seconds
