Reload Program Through Pin
11 years 2 months ago #61719 by Delron
Replied by Delron on topic Reload Program Through Pin
Tried all that, I think....
Can you do it in a M-code? Did not seem to work for me.
11 years 2 months ago #61720 by Delron
Here is one I tried with no success
M101
#!/bin/sh
halcmd setp halui.mode.mdi true
axis-remote -m "o100 call"
halcmd setp halui.mode.manual true
axis-remote —reload &
exit 0
Sure would like to see Linuxcnc create a method to deal with this problem in the next release.
11 years 2 months ago #61721 by PCW
Replied by PCW on topic Reload Program Through Pin
Still not convinced there is a problem
Nothing you have shown checks that the state has changed to the desired state before proceeding
11 years 2 months ago - 11 years 2 months ago #61722 by Delron
I'm not sure where I can check the state from for this to work?
Can the M-code do logic?
Would I place the hali.mode.is-manual in the M-code file and check there?
How do I pause the m-code until it is in manual mode before proceeding with the reload?
Can you give an example?
Last edit: 11 years 2 months ago by Delron. Reason: More questions
11 years 2 months ago #61723 by Delron
Ok, I think it's behaving I little more here, however, I cannot get the m-code to put the machine back to manual mode after the reload.??
11 years 2 months ago #61724 by PCW
Not the most elegant way but
a bash while loop in your script waiting for
halcmd getp halui.mode.is-mdi | grep true
Having a 0 exit code is a possibility for waiting for mode changes
Time to create page: 0.395 seconds
