- Thank you received: 994
BigJohnT wrote:
strykerg wrote: is it possible to reload the current program through a hal pin?
i'm building a sort of pendant which includes a button for touching off the current axis. the touch-off works however unless the program is reloaded the backplot does not reflect the offset properly. and the only solution I found is to reload program .
Starting over, when you press the touch off button on your pendant what is it doing exactly? I assume your not in the middle of a program or are you?
JT
