Reload Program Through Pin
11 years 2 months ago #61708 by Delron
Replied by Delron on topic Reload Program Through Pin
PCW wrote: what is the error?
(of course you cannot invoke this when running a program)
Running a z-probe routine evoked from a pendant.
Error is "can't do this in manual mode."
It does do it, just hangs for a long time then spits the error after reloading.
I see many other people having the same problem.
11 years 2 months ago #61709 by Delron
Same problem as this guy.
www.linuxcnc.org/index.php/english/forum...-vs-keyboard-end-key
this post led me to believe he may have solved it, but not for me. I'm running latest release.
11 years 2 months ago #61711 by PCW
Replied by PCW on topic Reload Program Through Pin
Wonder if there's is a race condition? (mode not changed before reload issued)
11 years 2 months ago #61714 by BigJohnT
Replied by BigJohnT on topic Reload Program Through Pin
If you get a wrong mode error then your code needs to check the mode and place LinuxCNC into the correct mode (MDI).
Take a look at halui modes.
www.linuxcnc.org/docs/2.7/html/man/man1/halui.1.html
You can also do this with the python interface.
JT
11 years 2 months ago #61715 by PCW
Thats why I was suggesting a race condition, a script that changes the mode
may have to wait until the mode change occurs before proceeding with operations that depend on the
requested mode change
11 years 2 months ago #61717 by BigJohnT
Exactly, if your changing to mdi mode you must wait for halui.mode.is-mdi to be true before marching on in your program.
JT
Time to create page: 0.298 seconds
