- Thank you received: 2181
Glade Panel in Axis blocks arrow keys
8 years 9 months ago #105263
Replied by cmorley on topic Glade Panel in Axis blocks arrow keys
looks likethis should do it for master:
Chris M
CMD.jog(self.emc.JOG_STOP, 0,0)
CMD.jog(self.emc.JOG_STOP, 0,1)
CMD.jog(self.emc.JOG_STOP, 0,2)
Chris M
- +Jan+
- Thank you received: 17
8 years 8 months ago - 8 years 8 months ago #105342
by +Jan+
Replied by +Jan+ on topic Glade Panel in Axis blocks arrow keys
Hey Chris,
Me too...
I upgraded again to Master, and did some tests, until now I was not able to fix the problem in Master. I had to change again "self.emc" to "linuxcnc". Now I do not get any error message on the Terminal (the print messages are displayed).
Here is my actual xembed code (the interesting parts) I use for Master 2.8.
At this point I am just glade we have made a positive step...
Me too...
#!/usr/bin/env python
# vim: sts=4 sw=4 et
XEmbed helper functions to allow correct embeding inside Axis
import gtk
import linuxcnc
CMD = linuxcnc.command()
def forward_press(w, e, fw):
if e.keyval in ignore:
return
g = fw.get_geometry()
fe = gtk2xlib(e, fw, g)
if not fe: return
fw.send_event(fe)
def forward_release(w, e, fw):
CMD.jog(linuxcnc.JOG_STOP, 0,0)
print 'stop0'
CMD.jog(linuxcnc.JOG_STOP, 0,1)
print 'stop1'
CMD.jog(linuxcnc.JOG_STOP, 0,2)
print 'stop2'
if not fe: return
if not fe: return
fw.send_event(fe)
window.connect_after("key-press-event", forward_press, fw)
window.connect("key-release-event", forward_release, fw)
window.add_events(gtk.gdk.KEY_PRESS_MASK)
window.add_events(gtk.gdk.KEY_RELEASE_MASK)
Last edit: 8 years 8 months ago by +Jan+.
8 years 8 months ago #105344
Sorry I did it again...You are right self.emc is wrong.
I'm copying and pasting code from another program.
You are a linuxcnc coder now!
Chris M
Chris M
- +Jan+
8 years 8 months ago #105355
by +Jan+
Haha don`t think so...
in my last post means, that I do not get any error on the shell, but the behaviour remains in master 2.8.:dry:ow I do not get any error message on the Terminal (the print messages are displayed).
8 years 8 months ago #105363
try:
CMD.jog(linuxcnc.JOG_STOP, 1,0)
CMD.jog(linuxcnc.JOG_STOP, 1,1)
CMD.jog(linuxcnc.JOG_STOP, 1,2)
Chris M
Chris M
- +Jan+
8 years 8 months ago #105410
by +Jan+
Thanks, that did the job.
I attach both xembed files, for 2.7 and 2.8, maybe it is helpful for someone.
Best wishes.
Jan
Best wishes.
Jan
Time to create page: 0.296 seconds
