Screen like Mach
8 years 1 month ago #117448 by pavelshakal
Replied by pavelshakal on topic Adding custom buttons
Thank you for taking my time. Glade I found. The installer is the most recent developer in the folder. Where to find the ini file. I look at the folders and do not see)))
8 years 1 month ago #117449 by pavelshakal
g-cod in what format do you create?
8 years 1 month ago #117457 by Todd Zuercher
Replied by Todd Zuercher on topic Adding custom buttons
The ini file is part of your machine configuration. You can have multiple machine configs installed on one computer. When you create a machine configuration or open a demo config that comes with Linuxcnc, that configuration is saved in a folder in your user's home (~/linuxcnc/configs/*config's name*/)
The machines I'm running with Linuxcnc are cnc routers, used primarily for wood carving and engraving. The g-code we run on them is pretty generic g-code output by the cam program we use (Enroute), then I modify the pre- and post- ambles of the files to suit each individual machine. This is the way it's been done here where I work since before my time here. Since then I have taken some steps to make the code less machine specific, and I've arranged it now so that most of the machines I've converted to Linuxcnc can all run off of the same g-code, but that is only about half of our carving machines and none of the larger cnc routers we mill with.
8 years 1 month ago - 8 years 1 month ago #117458 by pavelshakal
understan. I work mainly in 3d
Last edit: 8 years 1 month ago by pavelshakal.
8 years 1 month ago #117459 by pavelshakal
I think I need an interpretation? can 3d improve or accelerate?
8 years 1 month ago #117461 by Todd Zuercher
I'm not sure I understand what you mean by "3d improve or accelerate" But Linuxcnc should not have any problem carving that relief in the photo. You might need to experiment with G64 Pn settings (corner blending tolerance) to find the best balance of speed and precision for your machine and your application. Also remember the maximum acceleration rates of your machine will have a huge influence on the speed something like that carving can be milled.
Time to create page: 0.385 seconds
