Screen like Mach
8 years 1 month ago #117463 by pavelshakal
Replied by pavelshakal on topic Adding custom buttons
I do not know how to translate that would explain. if the g-code knows then the characters "J" and "K"
Can I help improve the quality?
8 years 1 month ago #117464 by pavelshakal
head around, I like this program
8 years 1 month ago #117467 by Todd Zuercher
Replied by Todd Zuercher on topic Adding custom buttons
Yes, Linuxcnc can use J and K arcs.
linuxcnc.org/docs/html/gcode/g-code.html#gcode:g2-g3
Actually the cam program I use does not use K, so the majority of the g-code I run on the carving machines doesn't have any arcs and is all done with short line segments.
8 years 1 month ago #117506 by pavelshakal
through glade I can add to the standard axis change
8 years 1 month ago #117647 by pavelshakal
8 years 1 month ago #117661 by Todd Zuercher
Not sure I understand your question.
The standard Axis usier interface can be augmented by Glade panels, by adding tabs to the display window or an extra pannel to the right but you can not use it to change the existing user interface.
If you want to use Glade to edit the user interface (not just create a VCP), you will need to start with one of the Glade based user interfaces such as Gscreen or Gmoccapy.
Time to create page: 0.351 seconds
