Screen like Mach
8 years 1 month ago #117674 by Grotius
Replied by Grotius on topic Adding custom buttons
@Pavel,
Linuxcnc is not as Mach3.
Your first statement : instaling linuxcnc is easyer then mach3.... okey, but then.
Custom screen design, and writing code behind the screen design is different then the easy mach3 screen designer
where you can choose macro or g-code or a Oem button code.
I assume you are using parport?
Maybe i can help you. Today i have made a clean install for a milling machine. This custom screen has all the mach related button's
I have to do the rpm's. In about 2 week's i got it ready.
8 years 1 month ago - 8 years 1 month ago #117695 by pavelshakal
Replied by pavelshakal on topic Adding custom buttons
I understand that these programs are not the same.
Sorry, I make mistakes, since I translate from my native language. And do not always understand in response)))
LPT port = parport then yes. The machine is already working and I really like how it works thanks to Linuxcnc. Just for comfort, there is not enough pair of buttons and screens.
Last edit: 8 years 1 month ago by pavelshakal.
8 years 1 month ago #117696 by pavelshakal
Sorry I there buttons did not push those on your avatar)))
8 years 1 month ago #117707 by tommylight
Replied by tommylight on topic Adding custom buttons
What is your native language ?
8 years 1 month ago - 8 years 1 month ago #117708 by pavelshakal
belarusian and second Russian
Turned on the timer! Thank you !. Also found a tick, a demonstration of processing speed
I need a couple more buttons. AND
I need a postprocessor for artkam
8 years 1 month ago #117777 by pavelshakal
I found the postprocessor * .ngc as I'm happy. I like how LinuxCNC works, so I did it yesterday. The size is 70x47 mm.
Time to create page: 0.257 seconds
