Weird intermittent bug involving proximity sensors and homing
- Mike@CNCproCuts.com
26 Apr 2019 22:36 #132030
by Mike@CNCproCuts.com
Replied by Mike@CNCproCuts.com on topic Weird intermittent bug involving proximity sensors and homing
What is weird is that I didn't change anything ...
29 Apr 2019 15:59 #132301
Here are the voltage values ... now the relays are not changing values ... getting worse
Drives disabled, port 7 opened = 24,2V
Drives disabled, port 7 closed = 0V
Drives enabled, port 7 opened = 24,2V
Drives enabled, port 7 closed = 24,2V ... the relay is now not working on all of them ...
How do I find a ground loop ?
Can you measure the 7i77 input 07 with a voltmeter relative to field power common
in both switch states and both drive enable states?
That is measure from TB8 pin 8 to TB2 (orange) pin 8 in all states
If you had a noise issue with serial communications I would expect to see
error pop-ups in axis
- Thank you received: 5320
29 Apr 2019 16:27 #132302
Replied by PCW on topic Weird intermittent bug involving proximity sensors and homing
Sounds a bit more like a missing/unconnected field common/ground so as soon as you enable the drives or turn on a relay, field common is pulled up to +24V
29 Apr 2019 17:38 #132305
Thanks ! Found an unconnected wire ... now everything works fine ... still don't know how it could have happened but ... that was the problem so thanks a lot for the insights
29 Apr 2019 17:41 #132307
the 7i84 inputs will have names like "hm2_5i25.0.7i84.0.0.input-00"
You should be able to find them in Halshow
I had not connected the VIN yet ... now I see it so thanks
01 May 2019 14:17 #132437
Thougt it was solved ... worked fine for 24hrs ... now the problem is back ... very strange ... could a ground loop take time to accumulate voltage ?
01 May 2019 14:51 - 01 May 2019 14:51 #132442
Closing it for 30 minutes ... now it works ... intermittent ... back to square one ...
Last edit: 01 May 2019 14:51 by Mike@CNCproCuts.com.
- Thank you received: 1472
01 May 2019 15:01 #132443
Replied by Todd Zuercher on topic Weird intermittent bug involving proximity sensors and homing
Sounds like a wiring problem somewhere. Check all your connections, plugs, etc. You said you found one loose connection, there could be others.
01 May 2019 16:57 #132449
Been checking ... didn't find anything ... must be a design error on my part for the grounding ...
- Thank you received: 4649
04 May 2019 16:52 #132749
Replied by andypugh on topic Weird intermittent bug involving proximity sensors and homing
be aware that cage clamp screw terminals can be 100% tight but that is no good if the wire is below the cage. So you need to pull each wire as well as check the screws.
Time to create page: 0.251 seconds
