Opening PlasmaC Axis Config in Maximised Form
  • thefabricator03
  • thefabricator03's Avatar Topic Author
  • Visitor
  • Visitor
31 Aug 2019 04:39 - 31 Aug 2019 04:39 #143703 by thefabricator03
Opening PlasmaC Axis Config in Maximised Form was created by thefabricator03
Hi Guys,
When I open my PlasmaC config using Axis it will always load and not open up but is minimized to the task bar,
Also when I click the link in the task bar it opens but is in its minimized form, I always need to click to maximize the screen.
How can I set it up so that when I click on the desktop icon it will open up without going to the task bar and fully maximized?
Last edit: 31 Aug 2019 04:39 by thefabricator03.
31 Aug 2019 07:42 #143707 by phillc54
Replied by phillc54 on topic Opening PlasmaC Axis Config in Maximised Form
In the ini file, [PLASMAC] section
change:
MAXIMISED = 0
to:
MAXIMISED = 1
31 Aug 2019 07:44 #143709 by pl7i92
you may have not searched
look here
forum.linuxcnc.org/forum/21-axis/29735-axis-modifications
search is always your best fiend and first try
31 Aug 2019 07:47 #143710 by pl7i92
  • thefabricator03
  • Visitor
  • Visitor
02 Sep 2019 05:49 #143880 by thefabricator03
Replied by thefabricator03 on topic Opening PlasmaC Axis Config in Maximised Form
Ok I have followed Phills advice with the setting in the ini file and that has fixed one of the problems.
The other is when I open my desktop shortcut the program opens minimized to the task bar. I have searched for the answer but I am not sure exactly what setting would be controlling that.
02 Sep 2019 07:15 #143886 by phillc54
What happens if you run your LinuxCNC config from a terminal?
  • thefabricator03
  • Visitor
  • Visitor
02 Sep 2019 07:35 #143887 by thefabricator03
This is what I get and it still opens minimized to the task bar,
plasma@plasma:~$ ~/linuxcnc-dev/scripts/linuxcnc
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/plasma/linuxcnc/configs/sws_plasma'
Machine configuration file is 'sws_plasma.ini'
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./sws_plasma.hal
twopass:found ./plasmac.hal
twopass:found ./sws_plasma_connections.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:42:f0
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 010 (P1-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i76e.0: IO Pin 011 (P1-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0: IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0: IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
note: MAXV max: 500.000 units/sec 30000.000 units/min
note: LJOG max: 500.000 units/sec 30000.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
Warning: Forward kinematics must handle duplicate coordinate letters:yy
Note:
Individual axis homing is not currently supported for
KINEMATICS_IDENTITY with duplicate axis letter <Y>
note: jog_order='XYZ'
note: jog_invert=set([])
Axis window is 1905 x 1050
*** upgrading material file if we needed to ...
02 Sep 2019 07:44 - 02 Sep 2019 08:43 #143888 by phillc54
Can you post your material file, something like <machine_name>_material.cfg
Edit2: It won't be that, but if you edit your material file and change [VERSION 1] to [VERSION 1.1] it will get rid of that upgrade nag.
Edit1: What flavour of Linux are you using?
Last edit: 02 Sep 2019 08:43 by phillc54.
02 Sep 2019 19:34 - 02 Sep 2019 19:34 #143927 by cmorley
Replied by cmorley on topic Opening PlasmaC Axis Config in Maximised Form
AFAIK this requires code in the .axisrc file.
(but maybe Phill covers this somewhere with PlasmaC)
                    # Find the largest size possible and set AXIS to it
                    maxgeo=root_window.tk.call("wm","maxsize",".")
                    try:
                       fullsize=maxgeo.split(' ')[0] + 'x' + maxgeo.split(' ')[1]
                    except:
                       fullsize=str(maxgeo[0]) + 'x' + str(maxgeo[1])
                    root_window.tk.call("wm","geometry",".",fullsize)
                    # Uncomment for fullscreen
                    #root_window.attributes('-fullscreen', True)
Last edit: 02 Sep 2019 19:34 by cmorley.
02 Sep 2019 23:09 #143968 by phillc54
Yeah, there is code in the USER_COMMAND_FILE to do that but the problem he has is that when he runs LinuxCNC it starts with Axis minimized.
Time to create page: 0.239 seconds
