Opening PlasmaC Axis Config in Maximised Form
  • thefabricator03
  • Visitor
  • Visitor
7 years 2 months ago - 7 years 2 months ago #143703 by thefabricator03
Opening PlasmaC Axis Config in Maximised Form was created by thefabricator03
Hi Guys,
When I open my PlasmaC config using Axis it will always load and not open up but is minimized to the task bar,
Also when I click the link in the task bar it opens but is in its minimized form, I always need to click to maximize the screen.
How can I set it up so that when I click on the desktop icon it will open up without going to the task bar and fully maximized?
Last edit: 7 years 2 months ago by thefabricator03.
7 years 2 months ago #143707 by phillc54
Replied by phillc54 on topic Opening PlasmaC Axis Config in Maximised Form
In the ini file, [PLASMAC] section
change:
MAXIMISED = 0
to:
MAXIMISED = 1
7 years 2 months ago #143709 by pl7i92
you may have not searched
look here
forum.linuxcnc.org/forum/21-axis/29735-axis-modifications
search is always your best fiend and first try
7 years 2 months ago #143710 by pl7i92
  • thefabricator03
  • Visitor
  • Visitor
7 years 1 month ago #143880 by thefabricator03
Replied by thefabricator03 on topic Opening PlasmaC Axis Config in Maximised Form
Ok I have followed Phills advice with the setting in the ini file and that has fixed one of the problems.
The other is when I open my desktop shortcut the program opens minimized to the task bar. I have searched for the answer but I am not sure exactly what setting would be controlling that.
7 years 1 month ago #143886 by phillc54
What happens if you run your LinuxCNC config from a terminal?
Time to create page: 2.962 seconds
