- Thank you received: 2100
Opening PlasmaC Axis Config in Maximised Form
- thefabricator03
- Visitor
7 years 1 month ago #143887
by thefabricator03
Replied by thefabricator03 on topic Opening PlasmaC Axis Config in Maximised Form
This is what I get and it still opens minimized to the task bar,
plasma@plasma:~$ ~/linuxcnc-dev/scripts/linuxcnc
LINUXCNC - 2.9.0~pre0
Machine configuration directory is '/home/plasma/linuxcnc/configs/sws_plasma'
Machine configuration file is 'sws_plasma.ini'
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found ./sws_plasma.hal
twopass:found ./plasmac.hal
twopass:found ./sws_plasma_connections.hal
Note: Using POSIX realtime
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: Hardware address: 00:60:1b:10:42:f0
hm2_eth: discovered 7I76E-16
hm2/hm2_7i76e.0: Smart Serial Firmware Version 43
Board hm2_7i76e.0.7i76.0.0 Hardware Mode 0 = standard
Board hm2_7i76e.0.7i76.0.0 Software Mode 0 = io_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 1 = io_ana_spin
Board hm2_7i76e.0.7i76.0.0 Software Mode 2 = io_enc_ana_spin_fv
hm2/hm2_7i76e.0: 51 I/O Pins used:
hm2/hm2_7i76e.0: IO Pin 000 (P1-01): StepGen #0, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 001 (P1-14): StepGen #0, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 002 (P1-02): StepGen #1, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 003 (P1-15): StepGen #1, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 004 (P1-03): StepGen #2, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 005 (P1-16): StepGen #2, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 006 (P1-04): StepGen #3, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 007 (P1-17): StepGen #3, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 008 (P1-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i76e.0: IO Pin 009 (P1-06): StepGen #4, pin Step (Output)
hm2/hm2_7i76e.0: IO Pin 010 (P1-07): Smart Serial Interface #0, pin TxData0 (Output)
hm2/hm2_7i76e.0: IO Pin 011 (P1-08): Smart Serial Interface #0, pin RxData0 (Input)
hm2/hm2_7i76e.0: IO Pin 012 (P1-09): IOPort
hm2/hm2_7i76e.0: IO Pin 013 (P1-10): IOPort
hm2/hm2_7i76e.0: IO Pin 014 (P1-11): Encoder #0, pin Index (Input)
hm2/hm2_7i76e.0: IO Pin 015 (P1-12): Encoder #0, pin B (Input)
hm2/hm2_7i76e.0: IO Pin 016 (P1-13): Encoder #0, pin A (Input)
hm2/hm2_7i76e.0: IO Pin 017 (P2-01): IOPort
hm2/hm2_7i76e.0: IO Pin 018 (P2-14): IOPort
hm2/hm2_7i76e.0: IO Pin 019 (P2-02): IOPort
hm2/hm2_7i76e.0: IO Pin 020 (P2-15): IOPort
hm2/hm2_7i76e.0: IO Pin 021 (P2-03): IOPort
hm2/hm2_7i76e.0: IO Pin 022 (P2-16): IOPort
hm2/hm2_7i76e.0: IO Pin 023 (P2-04): IOPort
hm2/hm2_7i76e.0: IO Pin 024 (P2-17): IOPort
hm2/hm2_7i76e.0: IO Pin 025 (P2-05): IOPort
hm2/hm2_7i76e.0: IO Pin 026 (P2-06): IOPort
hm2/hm2_7i76e.0: IO Pin 027 (P2-07): IOPort
hm2/hm2_7i76e.0: IO Pin 028 (P2-08): IOPort
hm2/hm2_7i76e.0: IO Pin 029 (P2-09): IOPort
hm2/hm2_7i76e.0: IO Pin 030 (P2-10): IOPort
hm2/hm2_7i76e.0: IO Pin 031 (P2-11): IOPort
hm2/hm2_7i76e.0: IO Pin 032 (P2-12): IOPort
hm2/hm2_7i76e.0: IO Pin 033 (P2-13): IOPort
hm2/hm2_7i76e.0: IO Pin 034 (P3-01): IOPort
hm2/hm2_7i76e.0: IO Pin 035 (P3-14): IOPort
hm2/hm2_7i76e.0: IO Pin 036 (P3-02): IOPort
hm2/hm2_7i76e.0: IO Pin 037 (P3-15): IOPort
hm2/hm2_7i76e.0: IO Pin 038 (P3-03): IOPort
hm2/hm2_7i76e.0: IO Pin 039 (P3-16): IOPort
hm2/hm2_7i76e.0: IO Pin 040 (P3-04): IOPort
hm2/hm2_7i76e.0: IO Pin 041 (P3-17): IOPort
hm2/hm2_7i76e.0: IO Pin 042 (P3-05): IOPort
hm2/hm2_7i76e.0: IO Pin 043 (P3-06): IOPort
hm2/hm2_7i76e.0: IO Pin 044 (P3-07): IOPort
hm2/hm2_7i76e.0: IO Pin 045 (P3-08): IOPort
hm2/hm2_7i76e.0: IO Pin 046 (P3-09): IOPort
hm2/hm2_7i76e.0: IO Pin 047 (P3-10): IOPort
hm2/hm2_7i76e.0: IO Pin 048 (P3-11): IOPort
hm2/hm2_7i76e.0: IO Pin 049 (P3-12): IOPort
hm2/hm2_7i76e.0: IO Pin 050 (P3-13): IOPort
hm2/hm2_7i76e.0: registered
note: MAXV max: 500.000 units/sec 30000.000 units/min
note: LJOG max: 500.000 units/sec 30000.000 units/min
note: LJOG default: 6.000 units/sec 360.000 units/min
Warning: Forward kinematics must handle duplicate coordinate letters:yy
Note:
Individual axis homing is not currently supported for
KINEMATICS_IDENTITY with duplicate axis letter <Y>
note: jog_order='XYZ'
note: jog_invert=set([])
Axis window is 1905 x 1050
*** upgrading material file if we needed to ...
Note:
- phillc54
7 years 1 month ago - 7 years 1 month ago #143888
by phillc54
Replied by phillc54 on topic Opening PlasmaC Axis Config in Maximised Form
[strike]Can you post your material file, something like <machine_name>_material.cfg[/strike]
Edit2: It won't be that, but if you edit your material file and change [VERSION 1] to [VERSION 1.1] it will get rid of that upgrade nag.
Edit1: What flavour of Linux are you using?
Last edit: 7 years 1 month ago by phillc54.
- Thank you received: 2181
7 years 1 month ago - 7 years 1 month ago #143927
Replied by cmorley on topic Opening PlasmaC Axis Config in Maximised Form
AFAIK this requires code in the .axisrc file.
(but maybe Phill covers this somewhere with PlasmaC)
# Find the largest size possible and set AXIS to it
maxgeo=root_window.tk.call("wm","maxsize",".")
try:
fullsize=maxgeo.split(' ')[0] + 'x' + maxgeo.split(' ')[1]
except:
fullsize=str(maxgeo[0]) + 'x' + str(maxgeo[1])
root_window.tk.call("wm","geometry",".",fullsize)
# Uncomment for fullscreen
#root_window.attributes('-fullscreen', True)
Last edit: 7 years 1 month ago by cmorley.
- phillc54
7 years 1 month ago #143968
by phillc54
Yeah, there is code in the USER_COMMAND_FILE to do that but the problem he has is that when he runs LinuxCNC it starts with Axis minimized.
7 years 1 month ago #144060
ahh right - I think devilspie was one solution.
help.ubuntu.com/community/Devilspie
certainly heavy handed though.
Chris M
Chris M
- thefabricator03
- Visitor
7 years 1 month ago - 7 years 1 month ago #144087
by thefabricator03
Phill,
Please see attached my ini file and material file.
Last edit: 7 years 1 month ago by thefabricator03.
Time to create page: 2.045 seconds
