- Thank you received: 2100
Opening PlasmaC Axis Config in Maximised Form
- phillc54
7 years 1 month ago #144093
by phillc54
Replied by phillc54 on topic Opening PlasmaC Axis Config in Maximised Form
Has this problem always existed or has it just started recently?
- thefabricator03
- Visitor
7 years 1 month ago #144094
by thefabricator03
Replied by thefabricator03 on topic Opening PlasmaC Axis Config in Maximised Form
It has always existed.
- phillc54
7 years 1 month ago #144095
by phillc54
Does it also happen if you run an Axis config that is not PlasmaC?
Does it happen if you run a Gmoccapy config?
What flavour of Linux are you using?
- thefabricator03
- Visitor
7 years 1 month ago #144096
by thefabricator03
I does the same thing on the other Axis Sims,
Does not do it on Gmoccapy,
And Linux Mint LMDE 3 Cindy 3.8.8 running 4.9.0-7-rt-amd64 kernel
- phillc54
7 years 1 month ago #144097
by phillc54
Use a file browser with hidden files enabled and check if you have a .axisrc file in your home directory. If you do, rename it and then try your machine config and an Axis sim.
- thefabricator03
- Visitor
7 years 1 month ago #144098
by thefabricator03
What do I rename it to?
Time to create page: 2.136 seconds
