- Thank you received: 486
I have been trying to adjust the cone size in plasmac but this setting seems to have no effect. Do you know if plasmac overrides this config somewhere?
Yes, I did see that setting and it seems to be working with axis but does not have an impact when using gmoccapy. I even found the code in glcannon.py but hard coding that doesn't have an impact
Thanks Clive...I did notice that poking around yesterday that QTplasmaC appears to be the path forward. It is a net new plasma table I am setting up so might make more sense to go straight there. Any issues running QTplasmaC on Linuxcnc 2.8.2? Or am I better waiting for 2.9 to go GA?
