editing active gcode list
- Thank you received: 2176
21 Mar 2023 09:59 #267220
Replied by Aciera on topic editing active gcode list
You are confusing things. The suggestion was:
/home/user/Documents/XYZA
and
~/linuxcnc/nc_files/subroutines
You have this in your ini:
Which means it looks in the directories:
/home/{your username}
and
The colon (not semicolon) can be used to list more than one path linuxcnc should look for subroutines. In the above example it would look in two placesSUBROUTINE_PATH=/home/user/Documents/XYZA:~/linuxcnc/nc_files/subroutines
and
SUBROUTINE_PATH=~:/linuxcnc/nc_files/subroutines
and
The following user(s) said Thank You: foam man
- foam man
- Thank you received: 5
21 Mar 2023 22:11 #267254
by foam man
Replied by foam man on topic editing active gcode list
1. should I have the subroutines set up at both of those locations?
2. do the actual sub files have to be mentioned, or just up to the file that they are in?
- foam man
22 Mar 2023 04:34 #267272
by foam man
it works!!!
the file names that are listed in the subroutine file need to have .ngc in the name
thanks for all your help.
the frogwire guy I was talking about before?
he sent me his MAIN SUB file
If anybody is interested in looking at it
If I ever have 2.9 or later for the m98 code so I can use the looping function
it works!!!
Time to create page: 0.083 seconds
