select jog axis
2 years 10 months ago - 2 years 10 months ago #288808 by TimP
select jog axis was created by TimP
How to select jog radio button on axis screen from hal? Or feed override?
I have tried to set those pins
axis.x.jog-enable
halui.axis.x.select
halui.joint.0.select
`halshow` showing that they are changed, but AXIS UI still doesn't reflect it.
For feed override
setp halui.feed-override.direct-value 1 setp halui.feed-override.count-enable 1 setp halui.feed-override.counts 8 setp halui.feed-override.scale 0.1 if i do setp halui.feed-override.counts 8 in halshow then it changes on AXIS UI, but why it doesn't work from hal file? Also i have tried to do this from post_gui.hal same result POSTGUI_HALFILE = postgui.hal What is proper order to load those?
Last edit: 2 years 10 months ago by TimP.
2 years 10 months ago #288826 by cakeslob
Replied by cakeslob on topic select jog axis
You might need to connect them to axisui pins
  • Aciera
  • Administrator
  • Administrator
2 years 10 months ago #288830 by Aciera
Replied by Aciera on topic select jog axis
The following user(s) said Thank You: TimP
2 years 10 months ago #288847 by TimP
Replied by TimP on topic select jog axis
i have only limited amount of pins from axisui, and none of them seems to fit for this
2 years 10 months ago #288851 by cmorley
Replied by cmorley on topic select jog axis
try setting the scale before the counts
2 years 10 months ago #288872 by TimP
thnx, well script from that thread does something with unchecking x radio button, so need to figure out how to check other axis.
Time to create page: 0.237 seconds
