select jog axis
23 Dec 2023 20:27 #288939 by TimP
Replied by TimP on topic select jog axis
with slight modification of python script from  forum.linuxcnc.org/38-general-linuxcnc-q...lect?start=10#281577
it is working now at least jog selection
i don't know why but i thought that all UIs should use some hal signals for representation of data. So changing `halui.axis.x.select` should be used by UIs.
23 Dec 2023 20:33 #288941 by rodw
Replied by rodw on topic select jog axis
There is no need for a GUI to get involved with external hardware. Thats what halui is for.
When GUIs extend their scope, we get a mess with differing configs for no reason.
23 Dec 2023 22:35 #288951 by cmorley
Replied by cmorley on topic select jog axis
No, halui does not integrate well with axis selection or jogging rates in GUIs.
Halui is really a UI all on it's own, it was not made to integrate with other GUIs.
Just in most cases you can make it work.
24 Dec 2023 04:19 #288964 by rodw
I have not tried with qtdragon but halui jogging has worked for me with dedicated pendant hardware on axis, gmoccappy, and qtplasmac. I helps that the pendant has a deadman switch that allows selection of teleop mode before the pendant can be used.. This was most visible on Gmocappy as it selected the jogging tab when pressed. I don't expect qtdragon would be any different and teleop mode selection would make it pretty seamless.
Using pendant buttons for continuous high and low speed jogging is a bit more complex and while it can be done with hal, writing a custom component makes it simpler to implement as it flattens thehall commands a lot.
24 Dec 2023 05:48 #288971 by cmorley
What I meant be not integrating well is if you try to say select jog speed in the GUI but jog with Halui or some other combination of Halui and GUI controls.
24 Dec 2023 10:24 #288986 by rodw
Possibly, but on a table rather than a mill, where you are walking around the machine with pendant in hand, you never touch the GUI jog buttons (they might be on the other side of the table). So its not an issue.
24 Dec 2023 20:05 - 25 Dec 2023 15:19 #289013 by TimP
well i didn't thought about this but it makes sense. If you have physical buttons and switches you don't need them on screen.
interestingly enough feed override and rapid now shown in ui with proper values
Last edit: 25 Dec 2023 15:19 by TimP.
15 Feb 2026 00:30 #342969 by NT4Boy
Replied by NT4Boy on topic select jog axis
When GUIs extendRod their scope, we get a mess with differing configs for no reason.
Rod, I use the Axis GUI as representing what the hardware controls on my Three axis mill have done and are doing. In particular when setting the tool offsets using the touch off gui buttons, If the X or Y axis instead of the z is selected, then the tool table gains an unexpected x or y offset. If you control the machine by the gui that's my lookout, but to move a big machine around you must use a pendant. I have mpg and three momentary buttons to select the axis for the mpg to drive. It is very easy for me to move the machine only with the pendant, and lastly touch down the z direction for work and tool touch off with the x still selected because my jog buttons are not reflected in the gui. Done it too many times.
But, today, I found the forum.linuxcnc.org/38-general-linuxcnc-q...ns/50151-axis-select  python script, and its transforming. The radio buttons move with the last jog axis selected, and I can stop worrying quite so much about stray tool table entries.
Time to create page: 0.289 seconds
