Hiden spindle control buttons in AXIS
08 Nov 2024 09:45 #314079 by COFHAL
Why are the spindle control buttons not visible in AXIS?
08 Nov 2024 10:10 #314081 by Aciera
08 Nov 2024 10:34 #314082 by COFHAL
Replied by COFHAL on topic Hiden spindle control buttons in AXIS
I already tried that but it didn't work, even though that pin (spindle.0.on) is connected in my configuration in the .HAL file.
08 Nov 2024 11:24 #314085 by tommylight
Replied by tommylight on topic Hiden spindle control buttons in AXIS
There are a lot of entries for the spindle in the hal and ini file.
Make another config with spidnle, copy the relevant stuff from spindle sections in both files.
08 Nov 2024 12:18 #314088 by Aciera
Replied by Aciera on topic Hiden spindle control buttons in AXIS
looking at, what I believe to be, the relevant code in '/home/dave/linuxcnc-dev/src/emc/usr_intf/axis/scripts/axis.py'
def forget(widget, *pins):
    if "AXIS_NO_AUTOCONFIGURE" in os.environ: return
    if hal_present == 1:
        for p in pins:
            if hal.pin_has_writer(p): return
    m = widget.winfo_manager()
    if m in ("grid", "pack"):
        widget.tk.call(m, "forget", widget._w)
forget(widgets.brake, "spindle.0.brake")
forget(widgets.spindle_cw, "spindle.0.forward", "spindle.0.on",
       "spindle.0.speed-out", "spindle.0.speed-out-abs", "spindle.0.speed-out-rps", "spindle.0.speed-out-rps-abs")
forget(widgets.spindle_ccw, "spindle.0.reverse",
forget(widgets.spindle_stop, "spindle.0.forward", "spindle.0.reverse", "spindle.0.on",
forget(widgets.spindle_plus,
forget(widgets.spindle_minus,
forget(widgets.spindlef,  "spindle.0.forward", "spindle.0.reverse", "spindle.0.on", "spindle.0.brake",
forget(widgets.spindlel,  "spindle.0.forward", "spindle.0.reverse", "spindle.0.on", "spindle.0.brake",
forget(widgets.spinoverridef,
for hal.pin_has_writer():
	".pin_has_writer('pin_name'): Return a FALSE value if a pin has no writers and TRUE if it does"},
Not sure but since the code is checking OUT halpins for 'writers' it might not be enough to assign the pin to a signal but it may actually need to connected to another pin.
08 Nov 2024 12:26 #314089 by Aciera
Looking at 'pin_has_writer':
PyObject *pin_has_writer(PyObject *self, PyObject *args) {
    char *name;
    if(!PyArg_ParseTuple(args, "s", &name)) return NULL;
    if(!hal_shmem_base) {
	PyErr_Format(PyExc_RuntimeError,
		"Cannot call before creating component");
	return NULL;
    hal_pin_t *pin = halpr_find_pin_by_name(name);
    if(!pin) {
	PyErr_Format(PyExc_NameError, "Pin `%s' does not exist", name);
	return NULL;
    if(pin->signal) {
	hal_sig_t *signal = (hal_sig_t*)SHMPTR(pin->signal);
	return PyBool_FromLong(signal->writers > 0);
    Py_INCREF(Py_False);
    return Py_False;
I would expect that this would give the signal 'spindle-on' the writer 'spindle.0.on':
net spindle-on <= spindle.0.on
But I'm really just guessing here.
Time to create page: 0.099 seconds
