Axis configuration not fully working on 2.9.6
- Fabse
04 Oct 2025 16:49 #335821
by Fabse
Axis configuration not fully working on 2.9.6 was created by Fabse
Hey guys,
my config works as i want it on linuxcnc 2.9.4. After updating to 2.9.5 (or 2.9.6) it does not anymore. It mainly is the pendant that is not working as before. I use a china pendant (XHC WHB04B). Most buttons don't work anymore. For example when staring my machine, I hit the "reset" button. With version 2.9.4 I can home my machine after that. With 2.9.6 nothing happens. Control via GUI seems to work just fine.
I think the problem must be related to one of these, or maybe both points in the changelog:
I hope someone of the pros on this forum can help me. I don't know how to solve this on my own.
- halui: on startup, set the first configured axis as ‘is-selected’ instead of X
- halui: Don’t create ‘halui.axis.’- pins for unconfigured axes
- Thank you received: 2176
04 Oct 2025 17:22 #335822
Replied by Aciera on topic Axis configuration not fully working on 2.9.6
If your config would need any of those pins it would not start up at all but fail with an error about a missing hal pin. The first place to troubleshoot your issue is to open the halshow tool and check the signals coming from the pendant.
- Fabse
04 Oct 2025 17:32 #335824
by Fabse
Replied by Fabse on topic Axis configuration not fully working on 2.9.6
Thank you for your quick response! I didn't think about it that way... So I don't have to worry about the pins not being created?
What could be the reason for some of the signals not being connected correctly? I mean, it was working on 2.9.4 after all. I managed to solve a lot of problems while setting up my machine, most of them thanks to posts on this forum. This issue i can not wrap my head around.
But I will do what you suggest and check the signals.
04 Oct 2025 17:50 #335825
No. Hal connections are created on startup when the hal files are read. If a hal pin used in any of your hal files was missing the config would not start at all. So your problem is not because of 'signals not being connected correctly'.
One thing to do is start your config from the terminal and check the output in the terminal. Another is to check the XHC WHB04B hal component using the halshow tool to confirm button press events are actually reaching your hal connections.
The following user(s) said Thank You: rodw, Fabse
- Fabse
06 Oct 2025 11:53 #335915
by Fabse
Ok, today I had the opportunity to check my signals. I started with analyzing the "reset" button, which is supposed to turn on/off the machine. When on version 2.9.4 the button toggles "halui.machine.on", which then activates "halui.machine.is-on". This is what I expected to see.
When on 2.9.6 I see that "halui.machine.on" is toggled, but i never get the "halui.machine.is-on" to become true. It isn't even true when I switch on the machine via the F2 key. The machine functions, but this pin never says it is on.
How could this be explained?
06 Oct 2025 15:41 #335923
If you open one of the sim configs and check "halui.machine.is-on" does it go true when you enable the machine with the gui button?
06 Oct 2025 17:03 #335927
I've just built the current 2.9 branch (ie 2.9.6) and tested "halui.machine.is-on" reacting to "halui.machine.on" and "halui.machine.is-off", works for me in both tested guis (axis, gmoccapy)
- Fabse
06 Oct 2025 18:44 #335932
by Fabse
Hey and thanks for the effort!
I tried a sim config and set the "halui.maschine.on" and I get "halui.maschine.is-on" to change state to on. With off it works in the other direction.
I then tried the same thing with my config (pendant off) and it works! When I turn my pendant on things go down hill... I then press the reset button on the pendant and I can get my "halui.maschine.is-on" to get stuck either on or off. If it is stuck, it does not change whith the GUI button either.
This is beyond confusing to me. Why does my cofig do that from version 2.9.5 onward?
- ChrisB_II
- Thank you received: 7
09 Oct 2025 21:27 #336176
by ChrisB_II
Replied by ChrisB_II on topic Axis configuration not fully working on 2.9.6
I've gone back to 2.9.4 because of a similar problem with 2.9.5/6.
At first all buttons on the pendant work fine until I try to call an MDI_COMMAND_xx. The command itself is not executed but afterward there is a zombie process and most of the buttons on the pendant stop working. In halshow all buttons and connected signals still show activity - even MDI_COMMAND_xx are getting called - but nothing happens. After restarting linuxcnc everything ist back to normal. With 2.9.4 this does not happen! Seems like something is wrong in 2.9.5/6...
The following user(s) said Thank You: Fabse
- Fabse
10 Oct 2025 12:06 #336190
by Fabse
Hey and thanks for your reply!
I experimented with version 2.9.6 for a bit, but I can not find the fault that causes my problems. It just does not make sense that my config functions perfectly when running 2.9.4 and then goes broken after updating to 2.9.5/6.
I also noticed that calling MDI commands does not work. I have a command that zeroes my z-axis, which I can activate via a pyvcp button. This does not work anymore.
I am a bit relieved that I am not the only one having issues after updating, but I would love to find a solution to all of this!
As for now, I will stick to 2.9.4..
Time to create page: 0.227 seconds
