Axis configuration not fully working on 2.9.6
- miniwini
- Thank you received: 4
20 Oct 2025 12:08 - 20 Oct 2025 12:10 #336759
by miniwini
Replied by miniwini on topic Axis configuration not fully working on 2.9.6
Thank you guys for the quick fix...
cheers miniwini
cheers miniwini
Last edit: 20 Oct 2025 12:10 by miniwini.
- Thank you received: 4155
21 Oct 2025 06:51 - 21 Oct 2025 14:39 #336821
Replied by rodw on topic Axis configuration not fully working on 2.9.6
Last edit: 21 Oct 2025 14:39 by rodw.
- Thank you received: 7504
21 Oct 2025 07:33 #336824
Replied by tommylight on topic Axis configuration not fully working on 2.9.6
2.7 ?
You mean 2.9.7 most probably.
- Thank you received: 4657
22 Oct 2025 07:06 #336867
00-checkin has been running for 1 day and 15 hours at the moment, the previous two builds were killed by me from the IRC interface after similar times stalled.
Replied by andypugh on topic Axis configuration not fully working on 2.9.6
I plan on doing so, but I will have to build all the variants by hand on a selection of VMs and RPis as Buildbot2 seems to be broken. It stalls at the end of the RIP builds: buildbot2.highlab.com/buildbot/#/gridAndy, if this is tested as working, can you build an official 2.9.7 release and put it on our repo for bookworm and Trixie?
temp folder does not sound very permanent
23 Oct 2025 19:34 #337006
It is a PC/server that checks and builds the debs for various version of Linux architectures, after getting stuff from github, as far as i can gather.
What exactly is BuildBot?
24 Oct 2025 02:21 #337024
any .Deb distributed by apt needs to be signed by a gpg key and that key needs to be from a trusted source.
when code changes are sent to the LinuxCNC repositories in git hub, a series of run time tests are triggered. If the tests all pass, the buildbot is triggered and fesh debs are built automatically for a number of distributions and then become available in our apt repository. To access these you also need the gpt key. The original LinuxCNC buildbot could no longer do its thing from about Debian 10 due to changes in the Linux/Debian way so it stopped and could never be jumpstarted to life for neweer distros....
A new buildbot in training was created but to this day it has never grown up into the official LinuxCNC buildbot but you can find it here.
buildbot2.highlab.com.
This workflow is different to the Debian way. To get into Debian, you need to upload the source to Debian's buildbots manually into unstable (sid) branch. As long as it works well, it is pushed to Debian testing and when a new Debian release is made, testing is promoted to stable (currently Trixie). Trixie is basically locked for the duration of the Debian version but there may be an opportunity to push bug fixes (eg 2.9.7) to a point release of Debian Trixie. pheww!
The following user(s) said Thank You: Unlogic,
Time to create page: 0.094 seconds
