How to connect buttons and files.
- Rick G
- Thank you received: 155
10 Apr 2011 10:17 #8736
by Rick G
Replied by Rick G on topic Re:How to connect buttons and files.
Yep that is for a subroutine, which is what I use. Never had occasion to try with to get a phyton program to work the way you describe.
As John pointed out you may want to look at ngcgui which you can embed in tabs for fast access to ngc files from AXIS. These can be quite powerful and easy to edit.
Rick G
Rick G
- Mike_Eitel
- Thank you received: 184
10 Apr 2011 11:01 #8737
by Mike_Eitel
Replied by Mike_Eitel on topic Re:How to connect buttons and files.
Yes I understood John's way.
But I wanted to stay with mainstream axis and pyvcp.
I prefer mainstream, otherwise it's easy to run into frustration, as happend with mocca....
It seems as I understood coorectly the functionality of O code..... Pitty, But
I'l stay on looking around for a solution.
THX to both of you, Rick and John.
Mike
Mike
- Mike_Eitel
10 Apr 2011 11:55 - 10 Apr 2011 11:57 #8738
by Mike_Eitel
OK Ihave partialy sucess:
In the ini file :
OPEN_FILE = /home/cnc/emc2/nc_files/EMC.ngc
Connect buttons of screen
HALUI =halui
[HALUI]
MDI_COMMAND = G0 X1 Y1 Z1
MDI_COMMAND = G0 X2 Y2 Z2
MDI_COMMAND = G0 X3 Y3 Z3
MDI_COMMAND = o<Tools/square> call
In the postgui / pyvyp.hal :
net cmd00 pyvcp.cmd00 halui.mdi-command-00
net cmd01 pyvcp.cmd01 halui.mdi-command-01
net cmd02 pyvcp.cmd02 halui.mdi-command-02
net cmd03 pyvcp.cmd03 halui.mdi-command-03
In my ncfiles I have a subdirectoty called tools and as examle herin the file square.ngc:
o<tools/square> sub
G0 Z1
G0 x0 y0
F 120
G1 x0 y0 z0
G1 x0 y10 z0
G1 x10 y10 z0
G1 x10 y0 z0
G1 x0 y0 z0
o<tools/square> endsub
M2
As soon as I press the button, all commands in the file are processed correctly.
That way I can predefine some G-code programms, runned without request.
I'll experiment with M1 and message to get additional information and safety on screen
Maybe I'l find also something for .py and jpg. ;-()
Mike
In the ini file :
HALUI =halui
[HALUI]
o<tools/square> sub
G0 Z1
G0 x0 y0
F 120
G1 x0 y0 z0
G1 x0 y10 z0
G1 x10 y10 z0
G1 x10 y0 z0
G1 x0 y0 z0
M2
Mike
Last edit: 10 Apr 2011 11:57 by Mike_Eitel.
- Rick G
10 Apr 2011 11:57 #8739
by Rick G
Perhaps Andy will jump in,
In the mean time have you looked at ...
www.linuxcnc.org/component/option,com_ku...d,6514/lang,english/
Rick G
Rick G
- Rick G
10 Apr 2011 12:01 #8741
by Rick G
Great, looks like your on your way.
Rick
Rick
- Mike_Eitel
10 Apr 2011 12:03 #8742
by Mike_Eitel
Yes Rick
I thibk this will be a good way to go.
I forgot about M101 etc.
Mike
Mike
- Thank you received: 4995
11 Apr 2011 13:19 #8758
Replied by andypugh on topic Re:How to connect buttons and files.
Mike_Eitel wrote:
If you want to call a Python file from a PYVCP button, I think that MDI_COMMAND M100 is probably the way to do it.
- Mike_Eitel
11 Apr 2011 13:37 #8760
by Mike_Eitel
Hi Andy
Yes Ricks way via M1ff commands works
I'm just in the phase to try the available python files and decide wich ones I want to use.
The only bad thing:
I have to copy the files to the base nc_files direktory and rename them to M101 to M1ff ... and make them executable.
I was not able to do it a bit more indircet ( by placing the calls inside those "command files" , means working with the original file names.py . )
Mike
The only bad thing:
Mike
- Mike_Eitel
15 Apr 2011 09:31 - 15 Apr 2011 09:39 #8923
by Mike_Eitel
Hi
I'm totaly frustrated.
I got everthing to work. Nice pyvcp. To metric adjusted phyton files. Calling the phyton files via M1xx command.
BUT no more transfer of data to the Axis screen..... !!!!!!!!!
I could identify some code that is reacting if the phyton program is called inside of Axis....
BUT I dont understand what I have to modify or if it is eventually impossible to get what I wanted ??
I have a downloadable (windows made) zip file on my www at www.eitel.ch/mechatronics/MeCNC/cnc.zip
a.) my complete configuration MeBigCNC2 ( having a second parport at D4000 )
b.\ a part of my nc_files with the M1xx commands and the "source" in the /tools subdirectory
I hope that I did not lost all those hours to "include" .py in axis via buttons ....
Mike
P.S.
I have choosen as username : cnc
Mike
P.S.
Last edit: 15 Apr 2011 09:39 by Mike_Eitel. Reason: File to big
15 Apr 2011 11:49 #8927
That looks quite elaborate.
I don't have access to an EMC2 machine just now (lunch break). What is it that isn't working? I suspect that the buttons are meant to call python files which create G-Code, and you are not seeing the G-code appear in the window?
Or have I misunderstood?
Time to create page: 0.093 seconds
