How to connect buttons and files.
- Mike_Eitel
- Thank you received: 184
15 Apr 2011 11:56 #8928
by Mike_Eitel
Replied by Mike_Eitel on topic Re:How to connect buttons and files.
Yes Andy
Problem is that the phyton progarm is strting as soon as I press abutton.
Everithing is fine.... BUT the transfer to Axis button is missing, you just see a QUIT button.
I looked into the code and found an "If statement"
I replaced the line for quit by the same command as it would treat normaly...
But no reaction . Nothing is transfered into Axis.
I hope somebody can tell me how to get the python into Axis, when it's called via the M1xx statements.
MIKE
MIKE
- BigJohnT
- Thank you received: 1176
15 Apr 2011 12:00 #8929
by BigJohnT
Replied by BigJohnT on topic Re:How to connect buttons and files.
Have you looked at the simple g code generators on the wiki site? They send g-code to Axis.
- BigJohnT
15 Apr 2011 12:00 #8930
by BigJohnT
Just looked at your M101 and yes you have...
- Mike_Eitel
15 Apr 2011 12:10 #8932
by Mike_Eitel
Yes John for sure
Very nide programs.... And I seached the web, but could not find more than those in the wiki pages.
They run fine and transfer to axis, as long as not started via M1xx
I fear that it's some kind of "environment" problem that can not be soved.
To be honest, I can modify the code, but do not understand who a phyton program is "embeddet" into Axis....
- BigJohnT
15 Apr 2011 12:10 #8933
by BigJohnT
This line determines if Axis it running:
IN_AXIS = os.environ.has_key("AXIS_PROGRESS_BAR")
I wonder if something is broken with that as I just ran face.py on my 10.04 with Axis sim up and running and I get Write to File instead of Send to Axis...
- Mike_Eitel
15 Apr 2011 12:12 #8934
by Mike_Eitel
Did you start by calling via pvycp button and renamed to a M1xx file in nc_files directory.
Thr effect is only occuring when started that way.
- BigJohnT
15 Apr 2011 12:16 #8935
by BigJohnT
No, I started it in a terminal so I could do a little debugging.
- Mike_Eitel
15 Apr 2011 12:24 #8936
by Mike_Eitel
Hi John
I did similar all time when modifiing the codes
And I started also via axis and file button .. works perfect
I started to workout how to solve with pyvcp, hal, ini, python. etc.
Did my prof of concepts. Tested all the -py you find in the tools directoy. Than I did all the pyvcp finish.
Last was copiyng to nc_files and renamimg to M1xx.
Started all of them via button. Super... Then I saw that transfer to Axis button was missing AT ALL programs.
Grrrr I'm frustrated... My stomache feeling is that there is a basic problem.... hope somebody can show me that I'm wrong.
Mike
Mike
- BigJohnT
15 Apr 2011 12:36 #8937
by BigJohnT
Seems like if you open the python with Axis the environment variable is there for the program... I'm guessing that executing the M101 is the same as running the program from a terminal so it is not spawned as a child process or something like that. I don't know off hand how to fix this. I think at one time I used the .axisrc file to add one to the Axis menu or something like that.
On another subject I have found that Deweys ngcgui to be much more powerful than the simple g code generators as you can string together several subroutines into a complete program. Something you can't do with the simple g code generators as they overwrite what is in Axis.
Hopefully someone that knows more than me can help you to get this up and going.
- Mike_Eitel
15 Apr 2011 12:54 #8940
by Mike_Eitel
Yes John I also hope there is somebody who van help me out of that hole.
I'm not a real programmer., have only some vague ideas about coding.
And I do not want to go the mgcgui way, seems to much effort for me.
Mike
Mike
