PC friert bei EMC start/PC freezes while EMC start
- DaZeller
25 Apr 2011 14:38 #9307
by DaZeller
PC friert bei EMC start/PC freezes while EMC start was created by DaZeller
Hallo,
ich bin ein ganz frischer EMC user. Und bislang sehr glücklich es geschafft zu haben meine Achsen zu konfigurieren.
Leider friert mein PC beim start von EMC immer ein...
was soll ich tun?
Ich bitte um Hilfe!
Hello,
I'm a brand new EMC user. And I'm happy cause I configured my axis successfully.
But my PC freezes while strating EMC...
what should I do?
please help!
was soll ich tun?
Ich bitte um Hilfe!
Hello,
what should I do?
please help!
- BigJohnT
- Thank you received: 1176
25 Apr 2011 22:40 #9314
by BigJohnT
Replied by BigJohnT on topic Re:PC friert bei EMC start/PC freezes while EMC start
Did you run the latency test for an extended period of time and use the number to set your base period? Usually if the PC is freezing when running EMC the base period is set so small that there is no time left for the GUI to function.
- DaZeller
26 Apr 2011 13:15 - 26 Apr 2011 13:47 #9334
by DaZeller
Replied by DaZeller on topic Re:PC friert bei EMC start/PC freezes while EMC start
Hi John,
thanks for your Help!
yes I did run the latency test.
I started glxgerars while running the Test...
And I placed the number to the base time.
I also tried to increase the base time to Tenfold. But the max value is I think 50000 so I took this but it don't work...
Last edit: 26 Apr 2011 13:47 by DaZeller.
- BigJohnT
26 Apr 2011 16:48 #9341
by BigJohnT
What was the max jitter from the latency test?
- DaZeller
27 Apr 2011 10:14 #9368
by DaZeller
I think about 19800...
but I take a look if I'm at Home...
- BigJohnT
27 Apr 2011 10:36 #9370
by BigJohnT
Also what kind of PC is it? Very new, very old, laptop...
- DaZeller
27 Apr 2011 11:04 #9374
by DaZeller
Its a relatively old CAD Workstation
1.8GHz (I think Pentium 4)
750MB RAM
750MB RAM
- BigJohnT
27 Apr 2011 11:15 #9376
by BigJohnT
With 750Mb of ram I suspect your PC is doing a whale load of disk swapping while loading EMC as you don't meet the minimum requirements for Ubuntu.
help.ubuntu.com/community/Installation/SystemRequirements
You might have better luck with the 8.04 LiveCd than the 10.04 on older PC's.
- DaZeller
27 Apr 2011 12:15 #9380
by DaZeller
OK.
I'm going to upgrade my RAM...
maybe there are some GIB corroding around...
Thanks for your help, John!
I'll give a report here after test with some more RAM.
PS: What bike are you riding on your picture? looks really big... I'm a biker to.
- BigJohnT
27 Apr 2011 12:29 - 27 Apr 2011 12:30 #9382
by BigJohnT
Last edit: 27 Apr 2011 12:30 by BigJohnT.
