PC friert bei EMC start/PC freezes while EMC start
27 Apr 2011 12:56 #9386 by DaZeller
that's really big...
I'm riding a Suzuki SV 650. Where I live (next to the Black Forrest an the Alps). We have small streets with sharp curves so you need a bike with less than 200Kg to have fun... ;-)
27 Apr 2011 14:44 #9399 by BigJohnT
Yes it is big at 1800 and some change cc's 6 cylinders and 850+lbs but you can still drag the pegs if you want to with this bike she corners very well for such a large bike. Oh and it can go from 0 to 140 mph faster than you can write the check for the ticket.
05 Jul 2011 18:49 #11173 by DaZeller
OK. I upgraded my RAM now. But the problems are the same...
Running the Steppconf-Wizzard is no problem (I'm also able to move the Axis during the the Setup :-D )
but if I start my config some bad things happens:
I could:
- move my mouse pointer
- listen to web radio (for hours)
I couldn't:
- switch the Desktop (ctrl + alt + left/right)
- get reaction on pressing the 'Num'-Key
- the pointer of the mouse is Black
- click on any thing
- change to tty1 (ore other else) using (ctrl + alt + F1)
05 Jul 2011 19:50 #11174 by BigJohnT
Did you run the latency test after upgrading your ram and use the jitter number in the Stepconf Wizard?
So your config starts up but the GUI seems frozen? This can be from having a base period too low.
06 Jul 2011 09:50 #11177 by andypugh
This sounds like the problem that RTAI has with some hardware OpenGL.
Stepconf doesn't use OpenGL, but Axis does.
As an experiment you can try changing the user interface in the INI file:
[DISPLAY]
DISPLAY = axis
change to
DISPLAY = tkemc
If that works then it strongly points to an OpenGL issue, and the solution is probably here:
wiki.linuxcnc.org/emcinfo.pl?TroubleShoo...oftware_based_OpenGL
06 Jul 2011 10:39 #11178 by DaZeller
Thanks for your Ideas.
I'll give you a feedbak as soon as I tryed something.
06 Jul 2011 12:31 #11179 by DaZeller
OK. the problem seems to be a axis problem.
I changed the Display=axis to display=tkemc an it works!
But this HMI isn't my style... I used Mach3 before ;-)
now I'm going to have a look after andypugh's link...
06 Jul 2011 14:07 #11182 by DaZeller
It works! :-)
I runn
sudo apt-get install libgl1-mesa-swx11
now axis is working well! :-)
08 Jul 2011 14:56 #11268 by DaZeller
hello guys,
I'll did some tests and everything works well! Great! :-)
i youst have to setup the reference switches for automatically homing...
maybe I'll do the first milling job today ;-)
thank you so much for your help!!!
Time to create page: 0.116 seconds
