pyvcp pin does not exist
7 years 5 months ago #133087 by Buddy002
pyvcp pin does not exist was created by Buddy002
I had a problem which no longer remember so I formatted the hard drive and reloaded software. everything worked fine until it tried to load the right side panel then I got in the debug window panel_option.hal ;5;pin pyvcp.Clamp does not exist. So I commented out that line in the file and the debug file kicked the next pin in the list. I have looked at these files for multiple days with no result. I have included Tree.hal for the Tree milling machine which calls panel_options.hal Panel_options supplies panel.xml with the pin assignments for the panel
File Name: Tree325.hal
File Size:12 KB
File Name: panel_options.hal
File Size:0 KB
File Name: panel.xml
File Size:2 KB
. If nothing is wrong with one of these files I could reload the system again.
7 years 5 months ago #133103 by andypugh
Replied by andypugh on topic pyvcp pin does not exist
Can we have the INI file too? That is what might be landing the panel code.
7 years 5 months ago #133134 by Buddy002
Replied by Buddy002 on topic pyvcp pin does not exist
Attached is the ini file
File Name: Tree325.ini
File Size:3 KB
7 years 5 months ago #133150 by andypugh
Nothing immediately leaps out as being wrong.
Can I suggest that you load LinuxCNC from the command line (command "linuxcnc" and see if there is any sort of clue.
I suspect that PyVCP simply isn't loading. The terminal output might supply a clue.
Also add the command "show pin" to the top of the "panel_options.hal" file to get a list of all the pins that exist at that point to appear in the terminal output.
7 years 5 months ago #133191 by Buddy002
Another concern that I have is that I use mousepad as a text editor. I tried to install Gedit but my Syntacit program loader is pointed a website that no longer exists. I tried to change the target without success.
7 years 5 months ago #133200 by andypugh
Probably good that it failed. I once installed Gedit on Debian and it installed all of Gnome desktop.
If you can’t get on with Mousepad try Geany. (I currently use Geany everywhere)
Time to create page: 7.031 seconds
