pyvcp pin does not exist
7 years 5 months ago #133343 by Buddy002
Replied by Buddy002 on topic pyvcp pin does not exist
show pin lists all the pins present
running linuxcnc from the command line results with a launch of the main panel no rightside panel and the final line reads " no option 'recent files in section ' DEFAULT':
I suppose Panel_options.hal should be listed in the DEFAULT section.
7 years 5 months ago #133457 by Buddy002
my current plan,
I ordered a new HD
I will load linuxcnc 2.6
Then I can upgrade to 2.7
According to Peter at Mesa 2.7 handles motion better.
7 years 5 months ago - 7 years 5 months ago #133462 by Clive S
Replied by Clive S on topic pyvcp pin does not exist
Buddy002 wrote: my current plan,
I ordered a new HD
Why would you want to load 2.6 ? Save your config folder on a usb stick. then load 2.7 on the new drive then update it to 2.7.14
use one of the wizards to make a working system then edit the hal and ini file with the contents of your config folder from the usb stick.
Last edit: 7 years 5 months ago by Clive S.
7 years 5 months ago #133580 by pl7i92
Replied by pl7i92 on topic pyvcp pin does not exist
if you got a new HD
use the newest ISO
if you will like to be at the TOP
use USPACE 2.8 master
Time to create page: 6.413 seconds
