halui analog jog (ref interfacing a shuttleXpress)
- gmouer
- Thank you received: 9
I have always used a shuttleXpress for jogging in mach3 and have been working for days to implement it into linuxcnc. I read everything I could find on external jogging and the recent shuttleXpress component but there is no info on anyone actually accomplishing the interface. I have experimented with the common method of setting it up using sim-encoder / encoder tied to axis's count input but was not real happy with the results, it is very rough and jerky without fine control.
I also experimented with using the analog jog input in halui. This gave MUCH better performance and control. BUT..... I ran into one BIG issue that I have not found a way around. The shuttleXpress also has 5 momentary pushbutton bit inputs, two of them I have always used for select-X and select-Z for jogging and hoped to do the same with linuxcnc. There is only one analog jog output from the shuttleXpress, so the need to SELECTIVELY tie that to either the X or Z axis is necessary. The halui analog jog input for each axis does not have any enable/disable capability that I have seen. I have also not found a way to "switch" analog signals on/off.
Any suggestions on how to selectively tie the analog shuttle jog pin to the X and Z halui-analog jog inputs selectively? (toggle between X and Z?)
Any help would be most appreciated. I am loving the power of linuxcnc so far.
George
- Rick G
- Thank you received: 155
You might look here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?HAL_Components
and an example here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
and here...
wiki.linuxcnc.org/cgi-bin/wiki.pl?Using_...ove_Your_CNC_Machine
It seems like you need to take the signal and connect it to a component to select which pin to output the signal depending on which button you have pressed, instead of connecting directly to the pin.
Rick G
- gmouer
"It seems like you need to take the signal and connect it to a component to select which pin to output the signal depending on which button you have pressed, instead of connecting directly to the pin" EXACTLY!!! , is there a component that will handle such things with ANALOG signals????????
The ShuttleXpress has been mentioned in a few documents and there is a new component for the Hal added specifically for it BUT no information on handling the problem I describe. This makes me wonder if anyone has actually ever completed interfacing a shuttle. Frank W. mentions the shuttle in his HidComp component (which I used) but I contacted him, he never actually tried it with a shuttles single analog output and had no suggestions.
- Thank you received: 4976
The "Touchy" interface uses a single jog wheel to jog all axes, so that might be one approach. However I am not sure how suitable Touchy is for a lathe.
To redirect the analogue value to a chosen halui.jog.N.analog pin you can probably use two mux2 components.
www.linuxcnc.org/docs/devel/html/man/man9/mux2.9.html
Connect one momentary button to each mux2, the analog value from the jogwheel to the in1 inputs, and then the mux2 outputs to each halui.jog pin.
I think you can leave the in0 pins unconnected and they will default to 0.
If you press both buttons with this scheme, both axes will move..
loadrt mux2 count=2
addf mux2.0 servo-thread
addf mux2.1 servo thread
net x-jog-enable shuttle.0.button1-out mux2.0.sel
net z-jog-enable shutttle.0.button2-out mux2.1.sel
net jog-speed shuttle.0.analog mux2.0.in1 mux2.1.in1
net x-jog mux2.0.out halui.jog.0.analog
net z-jog mux2.1.out halui.jog.2.analog
(Or something rather like that, I guessed the pin names)
- Thank you received: 5239
there nothing special about "analog" values, they are just numbers and what the MUX comps switch.
- gmouer
Thanks much again!
George
- gmouer
I dont see why MUX2 or MUX4 would not work, since they select floating point values,
I totally missed the fact that mux functionality handles analog signals!!! I am very gratefull for the help. I have done a lot of reading and hands on with emc in the last week. Linux and EMC are a lot different than Mach3 that I am used to. The learning curve is steep but appears to be more than worth the effort.
I ordered and received a 5i25 and 7i76 mesa combo this week for switching my 14x40 lathe retrofit from Mach to Linuxcnc. Learning my way around first though with the little 7x10 lathe with a Gecko g540.
Thanks again!
George
- Rick G
If you have not already be sure to check out the ngcgui for the lathe, real time saver.
Rick G
- gmouer
Rick, yes, I have scoped out NgcGui and have that in my plans for the near future. They seem to be functionally equal to Mach3's wizards (only better)
Thanks everyone for the help! I am learning.
- m8298
What are you using the center dial for?
