halui analog jog (ref interfacing a shuttleXpress)
28 Apr 2013 21:24 #33332 by m8298
So, when the shuttlexpress.c was written, how were the number of packets it uses determined? And how are the bit mask names determined?
28 Apr 2013 21:43 #33334 by andypugh
I expect that Seb put in HAL pins that reported the raw values, and stared intently at the numbers while operating the device.
I am working on generalising the driver, but not very rapidly.
As I said, just try changing the product ID and see if you end up with something that nearly works, but with only 4 buttons active.
29 Apr 2013 01:58 #33347 by m8298
sudo apt-get install git-core build-essential linuxcnc-dev
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev
cd linuxcnc-dev
{Edit src/hal/user_comps/shutlexpress.c}
./autogen.sh
./configure --prefix /usr
make
sudo make setuid
Andy, I tried this and at the point I get to the ./auto gen.sh, it says no such file or directory?
29 Apr 2013 04:25 #33352 by andypugh
Ah, sorry, you need to be in the src directory.
30 Apr 2013 05:53 #33412 by m8298
OK, now I get hung up at make.
It says: Makefile:55: Make file.inc no such file or directory. Makefile:66: *** Make file.inc must specify RTPREFIX and other variables. Stop.
30 Apr 2013 06:19 #33414 by andypugh
Did you ./configure?
30 Apr 2013 06:25 #33415 by m8298
Yes.
Could you give me the instructions again referencing there proper directory structure? I am not certain I was in the proper directory.
30 Apr 2013 06:29 - 30 Apr 2013 06:30 #33417 by andypugh
Yes.
You need to be on linuxcnc-dev/src
(Assuming you have put the git repository in linuxcnc-dev)
Then for testing.
./autogen.sh
./configure
make
sudo make setuid
That will create a run-in-place config, or it should tell you why it hasn't.
To use the run-in-place version you just compiled you need to move down a level to the linuxcnc-dev directory, then
. ./scripts/rip-environment
(Yes, that is dot space dot slash)
Then start linuxcnc or halrun from the same command prompt as you just ran the rip-environment script.
Last edit: 30 Apr 2013 06:30 by andypugh.
Time to create page: 0.080 seconds
