Hi
.............but I can not make my LinuxCNC, assume the value of the variable paramsaver.............
The automatic updating of tool number when Axis opens has come up recently in another thread
www.linuxcnc.org/index.php/english/forum...urret?start=30#35273
3 options are
Use M61 to update the number in gcode
Use M6Tn to update the number by trying to change to the number already in the spindle, so it will do nothing (if your toolchanger works that way) and update the number.
Change iocontrol so that a tool change sequence can be triggered for the current tool number as determined by the toolchanger component, or whatever is connected to the trigger pin.
Again will do nothing and the number is updated.
I used the latter way to write a new version of iocontrol, which is what
tld70 and
cncbasher are using.
If you want to use the modified iocontrol to do it, a rip build version and install build version for 2.6 are on the thread that
tld70 mentioned.
www.linuxcnc.org/index.php/english/forum...-tool?start=30#28977
