Well for one you are using ROOT on a Linux box, and that is never a good idea, from security standpoint and from the issues that arise with software that is made to run as a normal user with limited privileges, access to files and folders, etc.jurod wrote: Where is the problem? Please help.
jurod wrote:
Works OK on my config machineCode:halcompile --install --userspace /home/hcnc/linuxcnc/paramsaver.c
this no works. The paramsaver component was not created.Code:halcompile --compile --userspace /home/hcnc/linuxcnc/paramsaver.c
