- Thank you received: 49
Muzzer wrote: Unless I've defined the MDI_COMMANDs, presumably they make no sense. I'll try to figure out where those need to come from next.
ericg wrote: I am having difficulty in running linuxcnc with the error from the debug file saying xhc-hb04.hal:20 Pin 'axis.0.jog-enable' does not exist.
Also which file do these lines go in, I don't seem to have them anywhere, perhaps that is the issue.
[HALUI]
MDI_COMMAND=...
MDI_COMMAND=...
This is (or was, it might be fixed) a bug in Halui. One solution was to not load Halui, but the pendant relies on it, so that isn't an option here.vgraves wrote: And I've been able to get the "=0" button working, but when I use it, LinuxCNC switches back into joint mode, which is annoying. It does this after the Home and Origin buttons as well. Any way to prevent this?
Largely correct, yes. You need to connect the button hal pins to mdi-command HAL pins to run MDI commands. You can also connect buttons to HAL pins such as spindle-on and coolant.From what I can tell, the C program creates pins, and the hal file ties some of them to signals but relies on MDI commands for the rest. Is this basically correct, and if so, which ones am I supposed to complete?
