XHC-HB04 wireless MPG pendant HAL module
- dgarrett
- Thank you received: 297
www.linuxcnc.org/index.php/english/forum...dule?start=120#44056
There is now a hal pin named xhc-hb04.stepsize-up which will normally be connected like:
net mysigname xhc-hb04.button-step => xhc-hb04.stepsize-upExample configurations provided in 2.6 are:
configs/sim/axis/xhc-hb04/xhc-hb04-layout1.ini (16 button)
configs/sim/axis/xhc-hb04/xhc-hb04-layout2.ini (18 button)
configs/sim/axis/xhc-hb04/xhc-hb04-layout2_mm.ini (18 button)
Please see the README and txt files for more info (these appear when using the linuxcnc configuration picker):
configs/sim/axis/xhc-hb04/README
configs/sim/axis/xhc-hb04/xhc-hb04-layout1.txt
configs/sim/axis/xhc-hb04/xhc-hb04-layout2.txt
configs/sim/axis/xhc-hb04/xhc-hb04-layout2_mm.txt
If for some reason you want to continue using a version from the wiki with 2.6, you will probably need to rename the module (and hal pins) to avoid a naming conflict. Future bug fixes , improvements etc will be made to the code in the linuxcnc git tree
- vgraves
- vgraves
Copied the two .tcl files and the layout2.cfg file to my configuration folder.
Added the HALFILE references to my .ini file
Added the XHC-HB04_CONFIG, XHC-HB04_BUTTONS, & HALUI stanzas to my .ini file.
LinuxCNC starts up and functions. I've verified via the HAL Meter that the pendant axis selection switch and the jog wheel pins are working, but I am unable to jog.
I assumed the instructions would provide a more-or-less working pendant. Was I supposed to also edit my .hal file to connect some .and2 pins as was needed in the wiki version?
- dgarrett
unable to jog.
What are the _exact_ pin names you are referring to?
First step is to try one of the existing simulator configurations
using one that is appropriate for your pendant layout. If that works,
you may have missed something in your ini file.
I see an ommission in the README, it should mention that you need
[HAL]
HALUI = haluiThere might be errors reported at start up, to see these, start
linuxcnc in a terminal:
$ cd your_config_directory
$ source linuxcnc_root/scripts/rip-environment ;# if RIP build
$ linuxcnc name_of_config.iniand copy and post the output
Post your configuration: ini file and hal files.
- Muzzer
- Thank you received: 49
Initially most LCNC installations are going to look very similar and should be capable of running one of the simulations out of the box (mine is). A generic procedure for implementing the XHC pendant with just one of those would be very helpful. I'm more than qualified to act as your pet idiot if you want to perform an "idiot test" to validate that process. So far I've failed to get my MPG running...
The forum does a fantastic job of spreading the word and helping new adopters to get up and running but there are quite a few hurdles for the inexperienced which cause some serious head scratching. I hope I'm not sounding unreasonably critical! I'd like to help with the process but I'm afraid I'm not in a position (yet) to do so.
I appreciate all the great work and support you guys put in and I'll share my experiences as I implement my system. In the meantime, if somebody could help to identify the full set of changes required I'm sure there would be an appreciative audience and I'll be very happy to test them out!
Murray
- dgarrett
The demo was made with a fresh install of linuxcnc2.6 from the buildbot
(buildbot.linuxcnc.org) on ubuntu 13.10 (precise)
So, a good procedure is:
1) test pendant using one of the provided simulator configurations
2) if it works in simulator, follow README instructions to
adapt to a different configuration and adapt to your machine
3) if it doesn't work with any of the provided simulator configurations,
start in terminal and post all output
- Muzzer
My initial installation was created by running an image that (I think) contained both Ubuntu 10.04(?) and LinuxCNC 2.4 (possibly 2.3). There is note on the front page of linuxcnc.org that says "Note: Do Not upgrade Ubuntu from the installed version as it will prevent LinuxCNC from working.", so I was wary of upgrading to v12. Similarly, I didn't upgrade to the latest version of LinuxCNC..
However, I upgraded to 12.04 and 2.6.0 and the pendant worked immediately. This wasn't a step-by-step methodical approach, so I could only speculate what the differences are that allow the pendant to work. Presumably a variety of updates have been incorporated along the way and it may also be cleaner ie without any unauthorised changes from me.
Thanks again!
Murray
- vgraves
I was able to successfully run the layout2 simulation...pendant worked correctly.
When I start my configuration from a terminal, I get these messages:
xhc-hb04.tcl: !!! <hal.mdi-command-00> target pin does not exist, continuing
xhc-hb04.tcl: using std_start_pause_button
I also noticed that the XYZ positions in AXIS did not update when actually jogging the machine with the keyboard. But the pendant did not work either.
I've attached my ini and hal files. Any help you could provide would be appreciated.
Van
- dgarrett
typo: hal.mdi-command-00 should be halui.mdi-command-00xhc-hb04.tcl: !!! <hal.mdi-command-00> target pin does not exist, continuing
Your configuration uses non-trivkins kinematics (gantrykins).
It is not clear to me which jogging features actually work for non-trivkin configurations in linuxcnc2.6 and earlier releases (and current git master). Maybe it will get better with a joints-axis branch that folks are working on -- I have not investigated.
You should probably use the halui plus-minus jogmode -- I think you will be able to use the pendant to jog at variable rates but without exact step increments.
README
jogmodes:
normal: postion mode, the axis will move exactly regardless of how long it takes. Beware: the machine may keep moving after you stop rotating the jog wheel.
vnormal: velocity mode, the axis will stop when the wheel stops. Beware: the amount moved per wheel detent may be less than specified if the machine velocity and acceleration cannot accomplish the move in time.
plus-minus: halui plus-minus jogging (may be useful for world-mode jogging in non-trivkins machines).
To set up plus-minus jogmode in the ini file:
#jogmode = vnormal
jogmode = plus-minusPlease Log in or Create an account to join the conversation.
- vgraves
I notice the coordinate positions don't continuously update in the pendant while a program is running. If I change the axis switch during the program, the pendant display resets, and the values update for about 5 seconds, then they freeze. Is this the expected behavior since a pendant isn't usually needed while running a part program?
Now that the basic jog functionality is working, I'm curious as to how to change the behavior of the pendant. For instance, the GOTO-ZERO button run is configured to run an MDI command to move to 0,0,0. I'd like that to be axis-specific, depending on the position of the axis switch (i.e., only move one axis at a time to its zero). I'd also like the ZERO button to set the selected axis' current position to 0.
Would this have to be done in the tcl files, or are there things I would do in the ini/hal files?
Thanks.
