- Thank you received: 3
When using LIB:xhc-hb04.tcl (with the axis gui) and using:
the jogging accelerations are set to the altered values (val1,val2,...)Code:[XHC_HB04_CONFIG]mpg_accels = val1 val2 val3 val4
when using the pendant jog wheel _AND_ when using the keyboard arrow keys in
manual mode.
When the pendant rotary switch is in the Off position, unaltered accelerations
are used for keyboard jogging. (So the jogging accels will be higher with the
pendant rotary in the off position).
However, the pendant goes to sleep if no buttons are touched for some number of
seconds (xhc.hb04.sleeping is set to 1). (It is unclear to me what conditions
are prerequisites for the pendant to go to sleep but it is detected by the
driver). When a pendant sleep occurs, the xhc-hb04.jog.enable-off is also set
to 1 and keyboard jogging reverts to unaltered accelerations independent of
any pendant rotary switch position.
