XHC-HB04 wireless MPG pendant HAL module
- cmtunnel
05 Dec 2015 03:02 #66429
by cmtunnel
Replied by cmtunnel on topic XHC-HB04 wireless MPG pendant HAL module
Yeah it's a 3-axis. I modified the file to the best of my abilities but still not starting. i'll keep working on it.
05 Dec 2015 03:28 #66430
At the moment, we can't even guess what is wrong.
If you open a terminal window and type "linuxcnc" and copy/paste the error message here, then we can normally tell you exactly what is wrong.
Give us better clues, you get better help.
Replied by andypugh on topic XHC-HB04 wireless MPG pendant HAL module
- cmtunnel
05 Dec 2015 16:07 #66461
by cmtunnel
Sorry, meant to do that last night. I think this is what you want. I'll be around all day if you need more info.
thanks
LINUXCNC - 2.7.3
Machine configuration directory is '/home/chris/linuxcnc/configs/basic_lim_home_debounce_xhc'
Machine configuration file is 'basic_lim_home_debounce_xhc.ini'
Starting LinuxCNC...
Found file(REL): ./basic_lim_home_debounce_xhc.hal
Found file(REL): ./custom.hal
Found file(LIB): /usr/share/linuxcnc/hallib/xhc-hb04.tcl
xhc-hb04: waiting for XHC-HB04 device
xhc-hb04: found XHC-HB04 device
Pin 'halui.spindle.stop' was already linked to signal 'spindle-manual-stop'
while executing
"hal net pendant:half <= xhc-hb04.button-half => halui.spindle.stop"
("eval" body line 1)
invoked from within
"eval hal net $args"
(procedure "net" line 1)
invoked from within
"net pendant:$bname <= $fullbname => $thepin"
(procedure "connect_pins" line 35)
invoked from within
"connect_pins "
invoked from within
"if { ![namespace exists ::tp] || ([::tp::passnumber] != 0) } {
connect_pins ;# per ini file items: [XHC_HB04_BUTTONS]buttonname=pin
wheel_setup..."
(file "/usr/share/linuxcnc/hallib/xhc-hb04.tcl" line 529)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
Running HAL shutdown script
xhc-hb04: connection lost, cleaning up
[timestamp] [threadID] facility level [function call] <message>
[ 0.000000] [00001030] libusbx: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
[ 0.000124] [00001030] libusbx: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
LinuxCNC terminated with an error. You can find more information in the log:
/home/chris/linuxcnc_debug.txt
and
/home/chris/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
thanks
LINUXCNC - 2.7.3
while executing
invoked from within
invoked from within
invoked from within
"connect_pins "
invoked from within
wheel_setup..."
invoked from within
"source $filename"
invoked from within
and
- dgarrett
- Thank you received: 297
05 Dec 2015 16:09 #66462
by dgarrett
Replied by dgarrett on topic XHC-HB04 wireless MPG pendant HAL module
- cncbasher
- Thank you received: 202
05 Dec 2015 17:51 #66473
by cncbasher
Replied by cncbasher on topic XHC-HB04 wireless MPG pendant HAL module
while executing
this is the problem , you have it linked twice , is what it's saying , you can only link one
while executing
- cmtunnel
05 Dec 2015 19:56 #66479
by cmtunnel
I had to fix that one and a few others before it would start up. I appreciate the help. I don't know how to use the pendant yet but I did some jogging and the z-axis runs shaky when using the handwheel. Looks like an acceleration setting because the other two run silky smooth....so I'll start looking into that.
- ssparko
03 Jan 2016 05:29 #67742
by ssparko
Replied by ssparko on topic XHC-HB04 wireless MPG pendant HAL module
I'm having a problem with my new xhc hb04. It's a wired unit. Turning the hand wheel clockwise moves as it should, i.e. 0.001 per click. However turning counter clockwise moves roughly 0.300 in the positive direction.
This is on a BBB with machinekit. linuxcnc 2.7.0~pre0
Running the 'xhc-hb04' command line utility gives the following:
It seems to me the counter clockwise click should produce -1 instead of +255
I thought I would apt-get update but there seems to be some trouble with that too:
W: Failed to fetch deb.dovetail-automata.com/dists/wheezy/Release Unable to find expected entry 'main/binary-armel/Packages' in Release file (Wrong sources.list entry or malformed file)
04 00 00 11 00 00
04 00 00 11 00 0C
04 00 00 11 01 0C delta +1 <-Clockwise click
04 00 00 11 00 0C
04 00 00 11 00 0C
04 00 00 11 FF 0C delta +255 <-Counter clockwise click
04 00 00 11 00 0C
04 00 00 11 00 0C
04 00 00 11 00 0C
04 00 00 11 00 0C
04 00 00 11 00 0C
04 00 00 11 00 0C It seems to me the counter clockwise click should produce -1 instead of +255
- jepler
- User is blocked
- Thank you received: 33
03 Jan 2016 14:36 #67752
by jepler
Replied by jepler on topic XHC-HB04 wireless MPG pendant HAL module
ssparko said:
It looks like machinekit has a fix for a bug that could be your bug, back in july 2015. I don't know how you determine the specific git version of your software when using machinekit.this bug and its fix were not forwarded upstream from machinekit to linuxcnc, so as of today linuxcnc lacks any similar bug fix. I don't have any of the relevant hardware so I can't do any testing regarding this bug.
machinekit and linuxcnc diverged quite some time ago, so we may not be able to give you the most accurate advice about your software.This is on a BBB with machinekit. linuxcnc 2.7.0~pre0
commit 80f4db00d57a7b4083e49f58374722917d8537d8
Author: marksue <msuevern@googlemail.com>
Date: Fri Jul 3 23:26:44 2015 +0000
Fixed incorrect left\rigth jogging
diff --git a/src/hal/user_comps/xhc-hb04.cc b/src/hal/user_comps/xhc-hb04.cc
old mode 100644
new mode 100755
index c9a5e77..0a6703f
--- a/src/hal/user_comps/xhc-hb04.cc
+++ b/src/hal/user_comps/xhc-hb04.cc
@@ -388,7 +388,7 @@ void cb_response_in(struct libusb_transfer *transfer)
xhc.button_code = in_buf[1];
xhc.axis = (xhc_axis_t)in_buf[3];
- *(xhc.hal->jog_counts) += ((char)in_buf[4]);
+ *(xhc.hal->jog_counts) += ((signed char)in_buf[4]);
*(xhc.hal->jog_counts_neg) = - *(xhc.hal->jog_counts);
*(xhc.hal->jog_enable_off) = (xhc.axis == axis_off);
*(xhc.hal->jog_enable_x) = (xhc.axis == axis_x);Please Log in or Create an account to join the conversation.
- cncbasher
03 Jan 2016 16:01 #67758
by cncbasher
which build of machinekit are you using on your bbb ,
i would concider grabbing the latest , that fix should be in the latest bbb build
- blacksmith99
21 Feb 2016 20:29 #70455
by blacksmith99
Replied by blacksmith99 on topic XHC-HB04 wireless MPG pendant HAL module
Hello,
I have a working setup using the 5i25 by itself with the XHC-HB04 pendant. I'm trying to get a configuration going using the parallel port. The parallel port config works fine until I add the lines related to the pendant from the working 5i25 ini file.
Here is the error log. I can see that it's trying to link two pins to the same signal. I'm not sure what to do about it as it all works in the other configuration.
Any ideas?
Log Follows.
Thanks!
LINUXCNC - 2.7.4
Machine configuration directory is '/home/blacksmith99/linuxcnc/configs/SX3-Parallel_HB04'
Machine configuration file is 'SX3-Parallel_HB04.ini'
Found file(REL): ./SX3-Parallel_HB04.hal
xhc-hb04.tcl: using std_start_pause_button
Pin 'motion.spindle-speed-out-rps-abs' was already linked to signal 'spindle-cmd-rps-abs'
while executing
"hal net pendant:spindle-rps <= motion.spindle-speed-out-rps-abs => xhc-hb04.spindle-rps"
invoked from within
invoked from within
"net pendant:spindle-rps <= motion.spindle-speed-out-rps-abs => xhc-hb04.spindle-rps"
(procedure "wheel_setup" line 199)
invoked from within
"wheel_setup $::XHC_HB04_CONFIG(jogmode)"
invoked from within
wheel_setup..."
invoked from within
"source $filename"
invoked from within
[ 0.000000] [00001a2d] libusbx: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
[ 0.000597] [00001a2d] libusbx: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
/home/blacksmith99/linuxcnc_debug.txt
and
/home/blacksmith99/linuxcnc_print.txt
blacksmith99@linuxcnc:~$
Any ideas?
Log Follows.
Thanks!
LINUXCNC - 2.7.4
while executing
invoked from within
invoked from within
invoked from within
invoked from within
wheel_setup..."
invoked from within
"source $filename"
invoked from within
and
Time to create page: 0.163 seconds
