XHC-HB04 wireless MPG pendant HAL module
10 years 3 weeks ago #81491 by Spectre
I will have a look later when I get home. But I am sure on a right click on the mouse I couldnt find anything...but hey I have been wrong many times especially working with this
10 years 3 weeks ago #81493 by Spectre
It will not let me copy anything. I have right clicked left clicked...gone to the menu at top left and there is no copy function at all...I am using 2.7.7
10 years 3 weeks ago #81518 by andypugh
Spectre wrote: It will not let me copy anything.
Use the "select all" button and then Ctrl-C
10 years 2 weeks ago #81675 by dannym
How goes the project?
10 years 2 weeks ago #81676 by Spectre
Hi Danny
I had Sarah help me directly with it. It now works but it really is a mission to get LCNC to do anything. You pretty much have to be a coder. You can put a system INI in that works but there is always issues...having to comment parts out and not run them. Everything is so specific. As much as Mach3 is old and tired and slow it does work pretty much out of the box and reasonably easy to get going. There is not of course anything for fine tuning like you can in LCNC but everything so far has been a struggle getting this all to work.
When you think it all works then you go to make something and adding those new lines has stuffed something else up.... I have issues again now which I am trying to sort out. My spindle I finally got working like a treat..now after this the spindle wont work with the Gcode but does on the MDI...doh now what.
At least the MPG works on XYZ although the handwheel stepping on the Z axis is a bit notchy the X and Y and pretty good atr I find where to adjust the accell values
Mark
10 years 2 weeks ago #81677 by tommylight
Just to be sure, you are adding Sxxxx after the M3 in gcode, right?
That is the spindle speed where xxxx is. It has to be in hcode otherwise the spindle will not start in auto mode, but it will in MDI or manually by pressing F9.
Time to create page: 0.155 seconds
