XHC-HB04 wireless MPG pendant HAL module
9 years 9 months ago - 9 years 9 months ago #85467 by timmert
I believe they come original with 5m cable
I know that's the maximum for USB. But so far (knock knock) never had problems with it under Mach3.
I got the pendant working fine with the sample config.
But when I make the config ready for my own. It says the signals are already linked.
It's unclear to me how to get it working now. Not possible to have 2 signals on the same function?
Edit
Found it and got it working
The HAL file I received from the supplier contained already a config for a pendant (but not for the pendant I'm using).
When I removed all these settings the pendant is working.
Edit
Only thing that's not working is I can't zero Y and Z with the pendant
Zeroing X is working fine
Last edit: 9 years 9 months ago by timmert.
8 years 3 months ago #114036 by Lcvette
I just read this whole thing is there a solid finished revision and instruction anywhere now for this? I have a XHC WHB04-L from a previous Mach3 machine and never thought it may work on my big machine as a pendant, I would love to have it as a way to jog and have some control other than the main control panel, but it seems there is alot of confusion as to whats what from all the reading i just did. any direction would be much appreciated!
I am running a 7i92 with 7i76 and 7i77 using preempt RT stretch and linuxcnc version 2.7.13 at the moment.
Thanks in advance!
Chris
6 years 3 months ago #176625 by kang2k
Hello.
I buy pendant XHC-HB04 from alliexpress, but in linuxcnc not correct working.
Linuxcnc v 2.7.15
in sim, write "connection lost"
And so every few minutes
5 years 5 months ago #210879 by neodym
Unfortunately I couldn't get the xhc-hb04 to work under Linuxcnc2.8.0 / Debian10.
That has become very confusing and extensive. This only makes mistakes that are difficult to interpret.
The handwheel was originally intended for a lathe on a Mesa 5i20.
Should I have overlooked a current manual, I would be very happy to hear from you. Sample files are also very welcome.
Many thanks for your help
5 years 4 months ago #211135 by andypugh
Can you try updating to LinuxCNC 2.8.1 ?
This fix might be related:
github.com/LinuxCNC/linuxcnc/commit/85a8...648d52c9db242db8bd46
4 years 2 months ago #249935 by Samuelx
great video about setting up the hal file for mpg
