Getting error when installing a homebrew component
- Mr. Technical
06 Jun 2014 02:37 #47733
by Mr. Technical
Getting error when installing a homebrew component was created by Mr. Technical
Hi Guys,
A friend and I have been working on a tool changing component for my lathe and using the oracchanger component as a jumping off point to design it. We've covered some ground, but are hitting an error when trying to install it. The error says:' ValueError: need more than one value to unpack'
Any idea what's causing that?
Mr. Technical
Mr. Technical
- ArcEye
- Thank you received: 758
06 Jun 2014 13:23 - 06 Jun 2014 14:48 #47743
by ArcEye
Replied by ArcEye on topic Getting error when installing a homebrew component
The error is coming from comp
There is a syntax error in the file which is preventing it parsing.
Post the toolchanger comp
Last edit: 06 Jun 2014 14:48 by ArcEye.
- Mr. Technical
06 Jun 2014 20:27 #47754
by Mr. Technical
Replied by Mr. Technical on topic Getting error when installing a homebrew component
Hi ArcEye,
Here's what we've got so far. As I said, it's adapted from the oracchanger comp that you built. I'm sure we've got a long way to go with it, but any pointers are much appreciated.
Mr. Technical
Mr. Technical
- Mr. Technical
06 Jun 2014 20:46 #47755
by Mr. Technical
I just caught something. I need to make the component and the file name match. Strike 1. What else am I missing?
Mr. Technical
Mr. Technical
- ArcEye
06 Jun 2014 21:32 #47758
by ArcEye
The error comes from line 411 of comp (the program not your comp file
So it is connected to the filename, but not what you think, yes you are right the component and filename must be the same.
The problem is you have used a windoze editor and the file is littered with ^M symbols, which are completely throwing the parser out.
Open in gedit, do File > SaveAs and below the file listing change Line Ending to Linux/Unix and then save
PS
You have a variable called state
That name is protected, because it is the name given to the struct containing the created pins etc, use another name
def parse(filename):
initialize()
f = open(filename).read()
a, b = f.split("\n;;\n", 1)
p = _parse('File', a + "\n\n", filename)
if not p: raise SystemExit, 1
PS
- Mr. Technical
07 Jun 2014 04:02 #47763
by Mr. Technical
Thanks for the info, ArcEye. I have made the changes that you suggested. I changed the file name to pumachanger.txt, did a ctrl-H to replace every instance of 'state' with 'status', and resaved it with the correct linux line endings.
Now I'm getting the following errors when I try to compile it:
pumachanger.comp: In function ‘_’:
pumachanger.comp:195: error: implicit declaration of function ‘motor_freehwheel’
pumachanger.comp:196: error: ‘state’ undeclared (first use in this function)
pumachanger.comp:196: error: (Each undeclared identifier is reported only once
pumachanger.comp:196: error: for each function it appears in.)
pumachanger.comp:246: error: implicit declaration of function ‘turret_is_within_3mm’
pumachanger.comp:269: error: ‘turret_state’ undeclared (first use in this function)
make[2]: *** [/tmp/tmpSg27_Q/pumachanger.o] Error 1
make[1]: *** [_module_/tmp/tmpSg27_Q] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
make: *** [modules] Error 2
What have I done now?
Mr. Technical
Mr. Technical
- Mr. Technical
07 Jun 2014 05:30 #47764
by Mr. Technical
Kind of answering my own question here, but I've been fiddling with the file to get it to compile. Here's what it looks like now. It does in fact compile, but with 2 warnings:
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-2.6.32-122-rtai SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-122-rtai'
CC [M] /tmp/tmpXtpmLR/pumachanger.o
pumachanger.comp: In function ‘turret_is_within_3mm’:
pumachanger.comp:99: warning: control reaches end of non-void function
pumachanger.comp: In function ‘motor_freewheel’:
pumachanger.comp:89: warning: control reaches end of non-void function
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/tmpXtpmLR/pumachanger.mod.o
LD [M] /tmp/tmpXtpmLR/pumachanger.ko
I've not really been working on the logic of things, more just debugging.
How can I clear these two warnings?
Mr. Technical
MODPOST 1 modules
Mr. Technical
- ArcEye
07 Jun 2014 13:16 #47766
by ArcEye
Hi
You have declared a function which returns bool, but it does not return anything
Your earlier error with implicit declaration is because you have a typo in the function name you are calling
ie. motor_freehwheel(false);
I would advise that you bring the functions inline, within the main switch() block, but see how it works first
- Thank you received: 5013
09 Jun 2014 21:05 - 09 Jun 2014 21:05 #47813
The functions need to return _something_ if they are non-void.
So, change "return" to "return 0" or "return 1" as required.
Replied by andypugh on topic Getting error when installing a homebrew component
Last edit: 09 Jun 2014 21:05 by andypugh.
- Mr. Technical
24 Jun 2014 21:27 #48224
by Mr. Technical
I think I have addressed the fixes that you mentioned, and am now trying to net the pins together.
As I understand it, the iocontrol.0.tool-prep-number is netted to the tool-number signal
Whenever a tool number is called from MDI, iocontrol.0.tool-prep-number updates the tool-number signal. I'd like to tie that signal into my pumachanger function via the toolnumber pin, so:
In the custom_postgui hal file, I typed:
net tool-number <= pumachanger.toolnumber
Once I do that, I get this message:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
custom_postgui.hal:67: Pin 'toolnumber' does not exist
4859
PID TTY STAT TIME COMMAND
4930
Stopping realtime threads
Unloading hal components
This is confusing because I can see those pins and signals listed in the HAL Configuration window if I comment that line out.
By the way, I have added the pumachanger function to the servo-thread by entering the following at the end of the custom_postgui hal file:
addf pumachanger servo-thread
Any ideas on what I'm doing wrong?
4859
4930
Time to create page: 0.078 seconds
