Explaining mux_generic
15 Sep 2014 03:47 #51167 by Duc
Explaining mux_generic was created by Duc
Looking to update my system to use the mux_generic to take advantage of the increased tables. Coding is far from what I excel at.
Old sample code that I will need to increase from a 4 bit input to 5 input.
loadrt mux16 count=4
# --- Feedrate overide - FO-INCR-A ---
net fo-incr-a     <=  hm2_5i25.0.7i84.0.1.input-08
# --- FO-INCR-B ---
net fo-incr-b     <=  hm2_5i25.0.7i84.0.1.input-07
# --- FO-INCR-C ---
net fo-incr-c     <=  hm2_5i25.0.7i84.0.1.input-06
# --- FO-INCR-D ---
net fo-incr-d     <=  hm2_5i25.0.7i84.0.1.input-05
# connect feed overide increments - switches
    setp halui.feed-override.count-enable true
    setp halui.feed-override.direct-value true
    setp halui.feed-override.scale .01
net feedoverride-incr   =>  halui.feed-override.counts
net fo-incr-a           =>  mux16.1.sel0
net fo-incr-b           =>  mux16.1.sel1
net fo-incr-c           =>  mux16.1.sel2
net fo-incr-d           =>  mux16.1.sel3
net feedoverride-incr   <=  mux16.1.out-s
    setp mux16.1.debounce-time      0.200000
    setp mux16.1.use-graycode      False
    setp mux16.1.suppress-no-input False
    setp mux16.1.in00          0.000000
    setp mux16.1.in01          10.000000
    setp mux16.1.in02          20.000000
    setp mux16.1.in03          30.000000
    setp mux16.1.in04          40.000000
    setp mux16.1.in05          50.000000
    setp mux16.1.in06          60.000000
    setp mux16.1.in07          70.000000
    setp mux16.1.in08          80.000000
    setp mux16.1.in09          90.000000
    setp mux16.1.in10          100.000000
    setp mux16.1.in11          110.000000
    setp mux16.1.in12          120.000000
    setp mux16.1.in13          130.000000
    setp mux16.1.in14          140.000000
    setp mux16.1.in15          150.000000
On the mux_generic how does one combine multiple mux_generic in the hal code?
I.E. mux_generic.1="bb4,fu15" or mux_generic_fo="bb4,fu15"?
For the above code would this be correct?
mux_generic.1=="bb4,fu15"
# --- FO-INCR-B ---
# --- FO-INCR-C ---
# --- FO-INCR-D ---
net fo-incr-a           =>  mux_generic.1.1.sel0
net fo-incr-b           =>  mux_generic.1.sel1
net fo-incr-c           =>  mux_generic.1.sel2
net fo-incr-d           =>  mux_generic.1.sel3
net feedoverride-incr   <= mux_generic.1.out-s
    setp mux_generic.1.debounce-time      0.200000
    setp mux_generic.1.use-graycode      False
    setp mux_generic.1.suppress-no-input False
    setp mux_generic.1.in00          0.000000
    setp mux_generic.1.in01          10.000000
    setp mux_generic.1.in02          20.000000
    setp mux_generic.1.in03          30.000000
    setp mux_generic.1.in04          40.000000
    setp mux_generic.1.in05          50.000000
    setp mux_generic.1.in06          60.000000
    setp mux_generic.1.in07          70.000000
    setp mux_generic.1.in08          80.000000
    setp mux_generic.1.in09          90.000000
    setp mux_generic.1.in10          100.000000
    setp mux_generic.1.in11          110.000000
    setp mux_generic.1.in12          120.000000
    setp mux_generic.1.in13          130.000000
    setp mux_generic.1.in14          140.000000
    setp mux_generic.1.in15          150.000000
Once I get the pattern down I can increase the code to size easy.
15 Sep 2014 07:35 #51173 by andypugh
Replied by andypugh on topic Explaining mux_generic
You configure the size and data type of the mux in the "loadrt" line. Once the mux is loaded it has a fixed configuration.
loadrt mux_generic config=bb4,fu15
It doesn't seem that mux_generic supports the "names=" option to configure the name. I will beat the author until he fixes that.
15 Sep 2014 08:33 #51177 by Duc
Replied by Duc on topic Explaining mux_generic
so at most mux_generic can only exist once in the hal file? Since there is no naming convention.
15 Sep 2014 12:45 #51180 by cmorley
Replied by cmorley on topic Explaining mux_generic
loadrt mux_generic config="bs5,bs5"
would give you two muxes, with 5 bit input and s32 output
the pin names look like this:
mux-gen.00.in-bit-00
mux-gen.01.in-bit-00
mux generic doesn't have the gray code option so don't include that command
Andy if you fix the names= option, it would also be nice to have both the float and the s32 output pins available.
mux16 always has both out-s and out-f
I have come across situations where I have wanted to output to both types of pins at the same time.
In linuxcnc I wish we could connect s32 to float and vice versa directly.
Chris M
15 Sep 2014 17:53 #51188 by andypugh
No, you can have as many as you want, but they get sequentially numbered names over which you have no control. The sample configs rarely use "names=", you might not even have noticed that the option exists as a default for comp-based components.
15 Sep 2014 17:54 #51189 by andypugh
Is it too much trouble to use the conversion blocks when this is required?
15 Sep 2014 22:45 #51199 by cmorley
well comparing:
loading another component
making _another_ descriptives signal name
remembering to addf that component
to:
connect to an existing pin
just to connect two components together.
yes the conversion components are a bit of a pain and cludgy.
Is there a disadvantage to having both pins available?
Chris M
15 Sep 2014 22:52 #51200 by andypugh
The boolean, int and signed-int variants of mux_generic can run in the base thread, but the float versions can't.
16 Sep 2014 05:32 - 16 Sep 2014 05:33 #51210 by Duc
Working on the code some but running into some issues. The switch is a rotary switch that is either on or off so I did a bit input with a signed 32 bit output. 5 inputs from the rotary switch
Error code
Pin 'mux-gen.00.sel-bit000' does not exist.
Code Im trying
loadrt mux_generic config="bs5"
addf mux-gen.00 servo-thread
# --- FO-INCR-B ---
# --- FO-INCR-C ---
# --- FO-INCR-D ---
# --- FO-INCR-E ---
net fo-incr-e     <=  hm2_5i25.0.7i84.0.1.input-04
net fo-incr-a           =>  mux-gen.00.sel-bit000
net fo-incr-b           =>  mux-gen.00.sel-bit001
net fo-incr-c           =>  mux-gen.00.sel-bit002
net fo-incr-d           =>  mux-gen.00.sel-bit003
net fo-incr-e           =>  mux-gen.00.sel-bit004
net feedoverride-incr   <=  mux-gen.00.out-s32
    setp mux-gen.00.debounce-us      200000
    setp mux-gen.00.suppress-no-input False
    setp mux-gen.00.in-s32-00          0.000000
    setp mux-gen.00.in-s32-01          10.000000
    setp mux-gen.00.in-s32-02          20.000000
    setp mux-gen.00.in-s32-03          30.000000
    setp mux-gen.00.in-s32-04          40.000000
    setp mux-gen.00.in-s32-05          50.000000
    setp mux-gen.00.in-s32-06          60.000000
    setp mux-gen.00.in-s32-07          70.000000
    setp mux-gen.00.in-s32-08          80.000000
    setp mux-gen.00.in-s32-09          90.000000
    setp mux-gen.00.in-s32-10          100.000000
    setp mux-gen.00.in-s32-11          110.000000
    setp mux-gen.00.in-s32-12          120.000000
    setp mux-gen.00.in-s32-13          130.000000
    setp mux-gen.00.in-s32-14          140.000000
    setp mux-gen.00.in-s32-15          150.000000
Last edit: 16 Sep 2014 05:33 by Duc.
16 Sep 2014 05:53 #51212 by andypugh
I often find it helpful to load a component at a halrun prompt, just to try out the options and see what the pins are called.
andypugh@dn2800:~/git/linuxcnc-dev$ halrun
halcmd: loadrt mux_generic config=bs5
halcmd: show pin
Component Pins:
Owner   Type  Dir         Value  Name
     4  u32   IN     0x00000000  mux-gen.00.debounce-us
     4  bit   IN          FALSE  mux-gen.00.in-bit-00
     4  bit   IN          FALSE  mux-gen.00.in-bit-01
     4  bit   IN          FALSE  mux-gen.00.in-bit-02
     4  bit   IN          FALSE  mux-gen.00.in-bit-03
     4  bit   IN          FALSE  mux-gen.00.in-bit-04
     4  s32   OUT             0  mux-gen.00.out-s32
     4  bit   IN          FALSE  mux-gen.00.sel-bit-00
     4  bit   IN          FALSE  mux-gen.00.sel-bit-01
     4  u32   IN     0x00000000  mux-gen.00.sel-int
     4  bit   IN          FALSE  mux-gen.00.suppress-no-input
Time to create page: 0.066 seconds
