Explaining mux_generic
16 Sep 2014 06:38 #51216 by Duc
Replied by Duc on topic Explaining mux_generic
Pin 'mux-gen.00.sel-bit000' does not exist.
I often find it helpful to load a component at a halrun prompt, just to try out the options and see what the pins are called.
andypugh@dn2800:~/git/linuxcnc-dev$ halrun
halcmd: loadrt mux_generic config=bs5
halcmd: show pin
Component Pins:
Owner   Type  Dir         Value  Name
     4  u32   IN     0x00000000  mux-gen.00.debounce-us
     4  bit   IN          FALSE  mux-gen.00.in-bit-00
     4  bit   IN          FALSE  mux-gen.00.in-bit-01
     4  bit   IN          FALSE  mux-gen.00.in-bit-02
     4  bit   IN          FALSE  mux-gen.00.in-bit-03
     4  bit   IN          FALSE  mux-gen.00.in-bit-04
     4  s32   OUT             0  mux-gen.00.out-s32
     4  bit   IN          FALSE  mux-gen.00.sel-bit-00
     4  bit   IN          FALSE  mux-gen.00.sel-bit-01
     4  u32   IN     0x00000000  mux-gen.00.sel-int
     4  bit   IN          FALSE  mux-gen.00.suppress-no-input
Thank you for the tip. Will make the world of difference later on. Code all works now. Time to convert over the other 5 bit rotary switches.
Stupid question?
Why does the sliders not update till I actually move the rotary switches when the program first starts.
Boot up
Feedrate override reads 100% but switch is on 80%
Rotate knob
Feedrate override reads correct.
Corrected the command to loadrt mux_generic config=ss32
loadrt mux_generic config="ss32"
addf mux-gen.00 servo-thread
# --- Feedrate overide - FO-INCR-A ---
net fo-incr-a     <=  hm2_5i25.0.7i84.0.1.input-08
# --- FO-INCR-B ---
net fo-incr-b     <=  hm2_5i25.0.7i84.0.1.input-07
# --- FO-INCR-C ---
net fo-incr-c     <=  hm2_5i25.0.7i84.0.1.input-06
# --- FO-INCR-D ---
net fo-incr-d     <=  hm2_5i25.0.7i84.0.1.input-05
# --- FO-INCR-E ---
net fo-incr-e     <=  hm2_5i25.0.7i84.0.1.input-04
# connect feed overide increments - switches
    setp halui.feed-override.count-enable true
    setp halui.feed-override.direct-value true
    setp halui.feed-override.scale .01
net feedoverride-incr   =>  halui.feed-override.counts
net fo-incr-a           =>  mux-gen.00.sel-bit-00
net fo-incr-b           =>  mux-gen.00.sel-bit-01
net fo-incr-c           =>  mux-gen.00.sel-bit-02
net fo-incr-d           =>  mux-gen.00.sel-bit-03
net fo-incr-e           =>  mux-gen.00.sel-bit-04
net feedoverride-incr   <=  mux-gen.00.out-s32
    setp mux-gen.00.debounce-us      200000
    setp mux-gen.00.suppress-no-input False
    setp mux-gen.00.in-s32-00          0
    setp mux-gen.00.in-s32-01          10
    setp mux-gen.00.in-s32-02          20
    setp mux-gen.00.in-s32-03          30
    setp mux-gen.00.in-s32-04          40
    setp mux-gen.00.in-s32-05          50
    setp mux-gen.00.in-s32-06          60
    setp mux-gen.00.in-s32-07          70
    setp mux-gen.00.in-s32-08          80
    setp mux-gen.00.in-s32-09          90
    setp mux-gen.00.in-s32-10          100
    setp mux-gen.00.in-s32-11          110
    setp mux-gen.00.in-s32-12          120
    setp mux-gen.00.in-s32-13          130
    setp mux-gen.00.in-s32-14          140
    setp mux-gen.00.in-s32-15          150
    setp mux-gen.00.in-s32-16          160
    setp mux-gen.00.in-s32-17          170
    setp mux-gen.00.in-s32-18          180
    setp mux-gen.00.in-s32-19          190
    setp mux-gen.00.in-s32-20          200
16 Sep 2014 06:52 #51217 by andypugh
Replied by andypugh on topic Explaining mux_generic
Stupid question?
It's actually a very good question.
I _think_ that it is because the system is meant to be able to arbitrate between multiple inputs (GUI or halui) and so allows changes to the GUI to over-ride the switch and vice-versa.
This actually works more tidily with incremental encoders as the physical controls.
I thought that halui.direct-value was meant to over-ride that. Apparently not.
Can I suggest a feature request/bug report?
The following user(s) said Thank You: Duc
16 Sep 2014 08:11 - 16 Sep 2014 08:15 #51219 by Duc
Stupid question?
Bug report submitted. Also not the easiest page to find without a search.
Last edit: 16 Sep 2014 08:15 by Duc.
16 Sep 2014 08:26 #51220 by andypugh
[Bug report submitted. Also not the easiest page to find without a search.
Another fair point. It is directly linked from the "community" link at www.linuxcnc.org but I can't say that is the most obvious place to look.
16 Sep 2014 09:46 #51225 by cmorley
Replied by cmorley on topic Explaining mux_generic
Is there a disadvantage to having both pins available?
The boolean, int and signed-int variants of mux_generic can run in the base thread, but the float versions can't.
Well that's a pretty good reason :)
how about 'bsf5'
for a 5 bit input with s32 and float output?
Chris M
Or I could just suffer :)
16 Sep 2014 16:10 #51233 by andypugh
I just noticed something...
"bs5" is a really strange mux. It takes a pattern of bits or an integer and outputs either 1 or 0 into a signed32.
Is that really what was required?
17 Sep 2014 19:04 #51265 by Duc
For mine I had to use ss32 which still took 5 bit input and signed integers for the mux and a signed output.
I don't have access to my mill till Friday but can the input be change to something besides bit. I didn't see the input change away from bit when using "ss32"
17 Sep 2014 19:08 #51266 by andypugh
The _selection_ is always either based on bits or an S32 you can use either, or even both.
The letters control the data type of the multiple input values, and the single output value.
Time to create page: 0.190 seconds
