thewho wrote: ]Where does <tool_in_spindle> come from?
net car-enable motion.digital-out-00 carousel.0.enable
net car-ready carousel.0.ready motion.digital-in-00
net car-pos-req motion.analog-out-00 conv-float-s32.2.in
net car-pos-s32 conv-float-s32.2.out carousel.0.pocket-number
You probably should read the remapping page. Most of it isn't relevant, and there is a lot more there than you need to know, but it gives good background: linuxcnc.org/docs/2.7/html/remap/remap.htmlthewho wrote: No wonder I couldn't find them in your example config
But what about these, do I need to change them or are they just "internal" connections?
Code:net [b]car-enable[/b] motion.digital-out-00 carousel.0.enable net [b]car-ready[/b] carousel.0.ready motion.digital-in-00 net [b]car-pos-req[/b] motion.analog-out-00 conv-float-s32.2.in net [b]car-pos-s32[/b] conv-float-s32.2.out carousel.0.pocket-number
The "net" command automatically sets direction. See it like a bit of wire, the wire doesn't need to know the difference between the current source and the current sink.Do the hal-file I posted look good? Or did I net something the wrong way around?
thewho wrote: I'll give it a try as soon as I figure out how to disable the manual toolchange dialog that I have used so far..
