VMC related HAL questions.
6 years 10 months ago #152358 by CNCDoc
Replied by CNCDoc on topic VMC related HAL questions.
I load tool 1 to make Tool Touch Off. Then start the g code where tool 1 is used.
Starts a tool change sequence although the correct tool is already loaded.
Would this code fix it?
o998 IF [#<tool_in_spindle> = <selected_tool>] o<toolchange> RETURN o998 ENDIF
6 years 10 months ago #152368 by andypugh
Replied by andypugh on topic VMC related HAL questions.
That should work.
But should probably be
Return [1]
The following user(s) said Thank You: CNCDoc
6 years 10 months ago - 6 years 10 months ago #152422 by CNCDoc
Is it possible to make a reset button for the tool change sequence?
It is very hand-applied when something is not working and the arm is under the spindle. Must restart linuxcnc etc
If it is possible to make a button that resets as the arm goes out, the locking pin up the carousel stops positioning (resets all signals that are set high by the tool swap sequence).
Edit:
Will it be a .ngc file resetting with M66 P3. On all P # used?
Last edit: 6 years 10 months ago by CNCDoc.
6 years 10 months ago #152590 by CNCDoc
CNCDoc wrote: I load tool 1 to make Tool Touch Off. Then start the g code where tool 1 is used.
The code below seems to work:
o998 IF [#<tool_in_spindle> EQ #<selected_tool>] o<toolchange> RETURN [1] o998 ENDIF
6 years 9 months ago #154243 by andypugh
CNCDoc wrote: Is it possible to make a reset button for the tool change sequence?
I think so, if you can code it as a G-code subroutine.
Look at the MDI_COMMAND INI file entry:
linuxcnc.org/docs/2.7/html/config/ini-co....html#_halui_section
Though it might suffice to just use MDI to:
O<toolchange_reset> CALL
Time to create page: 0.123 seconds
