VMC related HAL questions.
7 years 1 month ago #143881 by pl7i92
Replied by pl7i92 on topic VMC related HAL questions.
beside compiling a user optimised comp
you shoudt be going with the system internal
depending on what system you are on 2.7 -2.9
you may be better up
as lots of changes appear to the system and comps do use this new feathers
7 years 1 month ago - 7 years 1 month ago #143883 by CNCDoc
Replied by CNCDoc on topic VMC related HAL questions.
I used it because I have the same milling machine thread starter.
Has 2.7.14 installed
Found this thread may be the same problem ..
forum.linuxcnc.org/24-hal-components/310...unent-debounce#75712
Last edit: 7 years 1 month ago by CNCDoc.
7 years 1 month ago - 7 years 1 month ago #143903 by CNCDoc
Loaded tool 3. Pocket 4 on the tool changer and in programs.
Unable to get photocell for tool in holder to interrupt tool change sequence.:dry:
7 years 1 month ago #143908 by andypugh
Replied by andypugh on topic VMC related HAL questions.
Which pocket is tool 3 in in the tool table?
(typically you will have more tools than pockets, so there is a separate entry in the tool table for the pocket)
The following user(s) said Thank You: CNCDoc
7 years 1 month ago #143909 by andypugh
You can also use Halmeter to check if the state of motion.digital-in-nn changes when there is a tool in the spindle.
7 years 1 month ago #143915 by CNCDoc
Removed tool 0. Now it works. Motion.digital-in-05 changes when I have tool in the spindel.
Time to create page: 0.498 seconds
