VMC related HAL questions.
7 years 1 month ago #144687 by andypugh
Replied by andypugh on topic VMC related HAL questions.
Why do you persist in using rising-edge with timeout rather than simply checking the state of the input?
7 years 1 month ago #144688 by CNCDoc
Replied by CNCDoc on topic VMC related HAL questions.
For the spindle to have time to index before alarm.
Was the idea.
6 years 10 months ago #151832 by CNCDoc
Receives the following error message when I load a g code with the tool changes.
I comment off the line N25 the file opens properly. The text of the error message is from my tool changer sequence.
1001) (T1 D=6.5 CR=0. TAPER=118DEG - ZMIN=-17.153 - DRILL) (T2 D=10. CR=0. - ZMIN=-15.4 - FLAT END MILL) N10 G90 G94 G17 G91.1 N15 G21 N20 G53 G0 Z0. (DRILL2) N25 T1 M6 N30 T2 N35 S3500 M3
What causes this?
File Name: toolchange...2-03.ngc
File Size:3.59 KB
6 years 10 months ago #151837 by andypugh
CNCDoc wrote: For the spindle to have time to index before alarm.
Was the idea.
Execution of the M19 won't complete until the spindle-is-oriented pin goes high.
linuxcnc.org/docs/2.8/html/gcode/m-code.html#mcode:m19
6 years 10 months ago #151838 by CNCDoc
Is this the cause of the error message above?
6 years 10 months ago #151839 by tommylight
Time to create page: 0.468 seconds
