The speed command should come from the position PID.thewho wrote: When M19 is active there is no speed command, it just enables the spindle so the rotation is just the drive drifting slowly.
Yes, just like that. In degrees.So how do I specify orient tolerance?
Code:setp orient.0.tolerance (number)
I'm not looking at any pins, the fact that I can stop the spindle with a light touch tells me that there probably is no speed output.andypugh wrote: When you say there is no speed command, where are you looking?
But orient mode should be using pid.1. You need to see what that one is doing to get orient to work.The screenshot shows a pid.0.output of 325.1263.
Is it line 11 I should edit?
To this?Code:net spindle-vel-cmd motion.spindle-speed-out pid.0.commandCode:net spindle-vel-cmd motion.spindle-speed-out-rps pid.0.command
Can I write the tolerance like this?And then add this line to the ini.Code:setp orient.0.tolerance [SPINDLE]ORIENT_TOLERANCECode:ORIENT_TOLERANCE = (number)
thewho wrote: I don't know when I can try anything on the machine next time, probably next weekend though
