Problem with homing ATC step motor
7 years 3 weeks ago #147214 by andypugh
Well, that looks OK.
You are running installed rather than run-in place LinuxCNC?
Is there any other carousel.so on your system?
7 years 3 weeks ago #147235 by CNCDoc
Installed following instruction 7.1 in the following link
linuxcnc.org/docs/html/getting-started/getting-linuxcnc.html
I'll check.
7 years 3 weeks ago #147247 by CNCDoc
The only carousel.so I find is in:
/ Usr / lib / linuxcnc / modules /
The carousel.so I'm using now comes from post 58732. If it does matter
7 years 3 weeks ago #147260 by andypugh
If you revert to the previous carousel component code and halcompile that, does it then work?
Is it _definitely_ a problem with carousel? If you comment out all references to carousel does the system then load normally?
7 years 3 weeks ago - 7 years 3 weeks ago #147265 by CNCDoc
If you revert to the previous carousel component code and halcompile that, does it then work? Yes
If you comment out all references to carousel does the system then load normally? Yes
Last edit: 7 years 3 weeks ago by CNCDoc.
7 years 3 weeks ago #147527 by andypugh
I am afraid that I am baffled then, as lots of people (including myself) have successfully used the new version so control lool changers.
There is less scope for weirdness than normal too, as Halcompile does most of the work, and that is well tested and compiles all the other components.
I suppose it is just possible that you are specifying an untested set of command-line parameters. What is your "loadrt" line?
Time to create page: 0.069 seconds
