- Thank you received: 62
I shy away from magnets on machine tools, they attract swarf.Tomorrow I publish the photos of the ATC. Regarding the sensors, I think I will use the hall effect switch, which are smaller and instead of drill holes, I will use neodymium magnets glued to a disk simulating a 3-bit gray code plus another for the index or strobe. in total 4 hall effect switch.
