Problem with homing ATC step motor
4 years 3 months ago #247065 by andypugh
How is carousel connected to the stepgen?
For a stepper you should probably have carousel.0.motor-vel connected to stepgen.N.velocity-cmd. If the changing sign of the velocity command does not change the rotation direction than it may be that the stepgen.N.dir pin (in software or hardware, or possibly both) is incorrectly connected.
4 years 3 months ago #247105 by COFHAL
Dear Andy.
# ATC MOTOR
# Step Gen signals/setup
setp hm2_7i96.0.stepgen.03.dirsetup [JOINT_2]DIRSETUP
setp hm2_7i96.0.stepgen.03.dirhold [JOINT_2]DIRHOLD
setp hm2_7i96.0.stepgen.03.steplen [JOINT_2]STEPLEN
setp hm2_7i96.0.stepgen.03.stepspace [JOINT_2]STEPSPACE
setp hm2_7i96.0.stepgen.03.position-scale [JOINT_2]STEP_SCALE
setp hm2_7i96.0.stepgen.03.step_type 0
setp hm2_7i96.0.stepgen.03.control-type 1
setp hm2_7i96.0.stepgen.03.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_7i96.0.stepgen.03.maxvel [JOINT_2]STEPGEN_MAXVEL
net a-enable <= carousel.0.active
setp carousel.0.fwd-dc 10000
setp carousel.0.rev-dc 10000
setp carousel.0.hold-dc 0
net carousel-vel <= carousel.0.motor-vel
net carousel-vel => hm2_7i96.0.stepgen.03.velocity-cmd
4 years 3 months ago #247106 by andypugh
try -10000 for the rev-dc
4 years 1 month ago #251296 by COFHAL
Thank you very much for your support, it is working now, the only thing I have noticed is that sometimes it does not take the shortest route to go to a tool and always does it in CW sense, other times it does it well.
4 years 1 month ago - 4 years 1 month ago #251297 by COFHAL
Last edit: 4 years 1 month ago by COFHAL.
4 years 1 month ago #251300 by COFHAL
Time to create page: 0.143 seconds
